 Post subject: WD Passport Pro 4TB recovery
PostPosted: December 17th, 2015, 21:27
Working on a WD Passport Pro 4TB drive that suffered water damage. The dual 2TB drives were configured in RAID 0, RAID chip on the board is ASM1061. Anyone have experience reconstructing these? I suspect like other Passport drives it has hardware encryption though I don't see an Initio chip on the PCB. Any option other than finding a replacement for the damaged Thunderbolt PCB interface?
 Post subject: Re: WD Passport Pro 4TB recovery
PostPosted: December 17th, 2015, 22:24
if it's water damage why did you got to a conclusion that only the PCB is damaged
but lets say is just the PCB
if you are not willing to spend a few bucks for a PCB replacement, i believe that the data is not important to you then move on
PostPosted: December 17th, 2015, 23:37
If you can upload a detailed photo of both sides of the PCB, then perhaps I could help you with voltage tests.
PostPosted: December 18th, 2015, 3:04
Can't say I've come across one of these exact beasts, but if the drives themselves are working connect the drives up and show us sector 0 from each.
PostPosted: December 18th, 2015, 4:34
The ASM1061 chip is just a PCI-E to SATA bridge.
We need more photos of everything so we can help you out further.
How much water damage is there? Were the drives powered on when the water damage happened?
I would be very cautious powering on these drives after water damage.
All hope of data recovery will be gone if there is one drop on the platters inside when the drive is powered on.
If there is water inside the drives, then this is not a DIY project.
Web: https://www.day1data.de
PostPosted: December 18th, 2015, 4:38
Any decent pro would not power up the drive after a water damage.
Actually, it's common sense.
PostPosted: December 18th, 2015, 4:43
Sorry didn't realise they were a pro. :shock:
PostPosted: December 18th, 2015, 4:54
Oh no, I do not know that either. That was a generic comment that I agree with what you said that you wouldn't power up the drive if there was water damage involved. :)
PostPosted: December 18th, 2015, 13:07
No water damage to the drives, they have been imaged. Will post pics of PCB. Not concerned about cost of replacing PCB, I just haven't been able to find the part, 4061-775137-003, anywhere.
PostPosted: December 18th, 2015, 13:13
See pics
PostPosted: December 18th, 2015, 13:27
So, it doesn't look like they're encrypted :-)
PostPosted: December 18th, 2015, 13:28
Load them up in UFS explorer
PostPosted: December 18th, 2015, 13:36
this too
PostPosted: December 18th, 2015, 13:39
Yes, indeed, it is not encrypted. I hadn't done a hex search yet, had just finished imaging when I originally posted and was assuming it was encrypted like other Passport drives. UFS Explorer detects this
PostPosted: December 18th, 2015, 15:54
The RAID volume begins and ends at sectors 0x64028 to 0xE8DC8887. I would examine sector 0x64028 on both drives.
PostPosted: December 18th, 2015, 20:19
Success! I've found the correct parameters and am currently extracting the data now. Block size was 32KB. Key to rebuilding correctly was ignoring the EFI partitions on each drive and building the RAID0 starting at sector 409640 on each drive. Oddly despite the correct settings UFS Explorer still wasn't able to detect partition contents but R-Studio loaded it up without any problems.
Thanks to those who offered helpful suggestions, esp fzabkar and pcimage.
Users browsing this forum: Google [Bot] and 207 guests
