Forum rules
 Post subject: looking for a pcb slotted post and screw.
PostPosted: December 19th, 2015, 22:06
Hi, Can anyone tell me the proper name or description for this:
I have done a search for many different terms such as slotted post, standoff, pcb crew etc and cant find anything. I want them as small as possible, the bottome being solderable or screwable to a PCB.
Anyone seen anywhere that sells stuff like this?
Thanks & cheers
 Post subject: Re: looking for a pcb slotted post and screw.
PostPosted: December 19th, 2015, 23:12
Pem nuts are similar. See the item "Self-Clinching Spinning Nut 1013" at the bottom of this page: http://www.pemnet.com/comp_lit_files/
PostPosted: December 20th, 2015, 2:35
Thanks Larry, I'll go through the catalogue :) quite tricky to Google for something you don't know the name for! I did a reverse image search and ended up with fish, lampshade and a starfish :)
PostPosted: December 20th, 2015, 9:40
Good luck, Brian. Also look at what Keystone offers. Here's a thread where someone was looking for something similar. Perhaps they will suggest search terms that help; many of the links mentioned are dead now.
PostPosted: December 20th, 2015, 14:38
Hey Bri, maybe take a look at these ?
http://www.verotl.com/en/category/proto ... components
or maybe adapt these ?
http://www.topline.tv/CCGA_column.html
regards
Kern
Голод не тётка!
