Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: SAMSUNG HM160HC ata user password
PostPosted: December 20th, 2015, 18:30
zenelli wrote:
I'll wait the hdd doesn't go anywhere :D
But how do you unlock the terminal?
terminal unlocked by using vendor specific commands through the interface
it's not the term.echo disable/enable (ED/EE)
PostPosted: December 22nd, 2015, 5:51
Greetings friends
I have a
which is locked by ATA password , following the above explained method faiing as SHT tool is not able to communicate with the HDD , although i am able to see the full log using windows hyper terminal ...
so the pins connection is good , but somehow , this piece of software is not working .. maybe because the HDD family is spinpoint F3 ?
any way i can extract modules using hyper terminal commands ?
thanks
PostPosted: December 22nd, 2015, 15:58
Ok,
i'll be waiting for the unlock procedure.
Thank's Moltke!!
PostPosted: December 23rd, 2015, 11:53
Spildit wrote:
Can you share the ATA VSC that will unlock the terminal ?
Thanks.
I'll think about it. but probably not. by themselves they are not needed and can be useful only to work with passwords
PostPosted: January 10th, 2016, 11:09
zenelli wrote:
Ok,
another part of the work is done.
the opportunity to unlock the drive without using any vsc cmd's from the interface is already being in the terminal
I'm sorry that everything is moving so slowly :)
PostPosted: January 12th, 2016, 16:08
Moltke wrote:
zenelli wrote:
Ok,
I have no hurry Moltke so take it easy :wink:
I have the drive more then a year in the closet and going nowhere,
i'm really gratefull your working on this.
Thank you!
Users browsing this forum: Google [Bot] and 57 guests
