 Post subject: TREX, ARCO FAILED! ERROR Code 0x84: INCOMPATIBLE PST VERSION
PostPosted: December 28th, 2015, 5:57
im run TREX in DOS.
When i run script COSOC.trx, I choose option [1] for MINI ARCO:
Please! help me fix it.
I'm sorry, my English is not good.
 Post subject: Re: TREX, ARCO FAILED! ERROR Code 0x84: INCOMPATIBLE PST VER
PostPosted: December 28th, 2015, 20:52
Spildit wrote:
Get some better tools like WDMarvell ?
Maybe you are attempting to run ARCO on a recent drive and TREX can't handle it ?
What is the drive model ? What is your version of TREX ?
Im used Trex 3.38. http://malthus.mooo.com/viewtopic.php?t=836
Im connected 2HDD WD (SATA interface) to my old PC via 2 port PATA (used SATA to PATA convert)
- 1st HDD 3.5: installed win98, TRex 3.38 in C:/Windows/Desktop/Trex3.38/Trex.exe
- 2nd HDD 2.5: Test this HDD (Product ID: B3h; Family: Saturn)
But i cannot run TRex under windows 98, Im used USB Hirent boot running ms-DOS and run TRex.
When i send command DiD, Im received info from 2nd.
Run script COSOC.trx >> ARCO FAILED! ERROR Code 0x84: INCOMPATIBLE PST VERSION. :(
Thank you very much!
PostPosted: December 29th, 2015, 0:03
When i send command DiD, Im received info from HDD 2.5.
PostPosted: February 27th, 2016, 6:42
change the port of cosoc.trx
Users browsing this forum: No registered users and 98 guests
