Back region to oryginal state and SA module's work look:
checked all modules Work, but contents mod 03, 0C is incorrect, mod 31, 33, 36 are empty
which does not change the fact that access to UA should be, and it is not.
So we are at the point of entry, ie,SA working, but there is no access to the User Area.
In contrast, as presented current insight into the zone table:
All heads are the same entries.
A current disk parameters immediately after the procedure Arco present themselves in this way:
Drive config
Format version = 0x0101
DCM Selection = 0x0001
cur_stroke = 0x0001
phy_heads = 0x0008
used_heads = 00008
cur_capacity = 0x4E20
max_fmt_LBAs = 3907709568 - 2000Gb
target_capacity = 0x0002
max_target_LBAs = 3907029167 - 2000Gb
hq_capacity = 0x0002
max_HQ_LBAs = 3907709568 - 2000Gb
final_capacity = 0x0002
z0_dtpi = 0x0003665C
z0_kfci = 0x00000014
cur_svo_TPI = 0x00038270
cur_data_TPI_0 = 0x00035F57
cur_data_TPI_1 = 0x00035F57
cur_data_TPI_2 = 0x00035F57
cur_data_TPI_3 = 0x00035F57
cur_data_TPI_4 = 0x00035F57
cur_data_TPI_5 = 0x00035F57
cur_data_TPI_6 = 0x00035F57
cur_data_TPI_7 = 0x00035F57
cur_data_TPI_8 = 0x00000000
cur_data_TPI_9 = 0x00000000
cur_KFCI_0 = 0x09C4
cur_KFCI_1 = 0x09C4
cur_KFCI_2 = 0x09C4
cur_KFCI_3 = 0x09C4
cur_KFCI_4 = 0x09C4
cur_KFCI_5 = 0x09C4
cur_KFCI_6 = 0x09C4
cur_KFCI_7 = 0x09C4
cur_KFCI_8 = 0x0000
cur_KFCI_9 = 0x0000
max_LBA_for_head_0 = 488463696 - 250Gb
max_LBA_for_head_1 = 488463696 - 250Gb
max_LBA_for_head_2 = 488463696 - 250Gb
max_LBA_for_head_3 = 488463696 - 250Gb
max_LBA_for_head_4 = 488463696 - 250Gb
max_LBA_for_head_5 = 488463696 - 250Gb
max_LBA_for_head_6 = 488463696 - 250Gb
max_LBA_for_head_7 = 488463696 - 250Gb
max_LBA_for_head_8 = 0 - 0Gb
max_LBA_for_head_9 = 0 - 0Gb
max_user_cyls_for_head_0 = 0x00000000
max_user_cyls_for_head_1 = 0x00000000
max_user_cyls_for_head_2 = 0x00000000
max_user_cyls_for_head_3 = 0x00000000
max_user_cyls_for_head_4 = 0x00000000
max_user_cyls_for_head_5 = 0x00000000
max_user_cyls_for_head_6 = 0x00000000
max_user_cyls_for_head_7 = 0x00000000
max_user_cyls_for_head_8 = 0x00000000
max_user_cyls_for_head_9 = 0x00000000
max_virt_cyls_for_head_0 = 0x00034101
max_virt_cyls_for_head_1 = 0x00034101
max_virt_cyls_for_head_2 = 0x00034101
max_virt_cyls_for_head_3 = 0x00034101
max_virt_cyls_for_head_4 = 0x00034101
max_virt_cyls_for_head_5 = 0x00034101
max_virt_cyls_for_head_6 = 0x00034101
max_virt_cyls_for_head_7 = 0x00034101
max_virt_cyls_for_head_8 = 0x00000000
max_virt_cyls_for_head_9 = 0x00000000
rsvd_svo_cyls = 0x0200
rsvd_data_cyls = 0x0100
max_user_svo_cyls = 0x00000000
max_svo_cyls = 0x00039780
trks_per_clstr_svo = 0x0080
trks_per_clstr_rsvd = 0x0000
trks_per_clstr_for_head_0 = 0x0000
trks_per_clstr_for_head_1 = 0x0000
trks_per_clstr_for_head_2 = 0x0000
trks_per_clstr_for_head_3 = 0x0000
trks_per_clstr_for_head_4 = 0x0000
trks_per_clstr_for_head_5 = 0x0000
trks_per_clstr_for_head_6 = 0x0000
trks_per_clstr_for_head_7 = 0x0000
trks_per_clstr_for_head_8 = 0x0000
trks_per_clstr_for_head_9 = 0x0000
HdMap TPI = 0x31 0x31 0x31 0x31 0x31 0x31 0x31 0x31
HdMap Capacity = 0x04 0x04 0x04 0x04 0x04 0x04 0x04 0x04
Head map TPI, and capacity, max LBA, CURRENT DATA TPI for all head is incorrect.
