Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: CA_FLUSH_ALL_GOT_CANCELED - what's wrong?
PostPosted: January 3rd, 2016, 20:19
Yes drive writes modules perfectly without errors . Yes, Sa normal start without problems. But arco can't calibrate this drive because arco can't access to user area. Btw I will try record this sytuaution What is happening with the disc. OK?
PostPosted: January 3rd, 2016, 20:27
ie there is no error CA_FLUSH_ALL_GOT_CANCELED?
Well, what then prevents restore the original modules?
and 03h, and 0Ch including? :shock:
PostPosted: January 4th, 2016, 8:23
Yes, SA Initialized propertly, No Error :arrow: CA_FLUSH_ALL_GOT_CANCELED, But i can,t access to User Area, ARCO procedure Can't access to User Area, no SLOW responding.
No pro equipment, WD Marvel is not able to restore module 03, only restore P-list from selftest logs.
Understand me?
Btw :arrow: I will try record this sytuaution What is happening with the disc. OK?
PostPosted: January 4th, 2016, 9:10
and what caused this error? why she disappeared? :shuffle: :spy:
PostPosted: January 4th, 2016, 14:34
Nothing, but problem It occurs when you need access to the User Area, then everything locks up and you receive an error CA_FLUSH_ALL_GOT_CANCELED understand me?
PostPosted: January 4th, 2016, 14:58
Yes. now understood
PostPosted: January 4th, 2016, 15:02
Moltke wrote:
Yes. now understood
Great, Therefore I suspect the MCU, or bad solder connection on PCB.
PostPosted: January 5th, 2016, 18:01
pikus_09 wrote:
Moltke wrote:
Yes. now understood
well, Moltke friend you are right, the problem is SA(SA modules), I write another Firmware: Ver: 00050065F and NO error-> CA_FLUSH_ALL_GOT_CANCELED.
Everything work's fine. :shock: , and now try to run ARCO seqence in WD MARVEL and adapt new firmware in my drive. Case Solved!!
PostPosted: January 6th, 2016, 7:24
Case Solved!!
I (and hopefully not only) is still in the research process
a preliminary conclusion, it is a new manifestation of the Slow responding
PostPosted: January 6th, 2016, 7:51
I think so, but in my case the problem was from the beginning with FW ie contents of damaged critical modules, one with the other invalid. Well then we'll see if in the end ARCO will begin to work with the drive. :?
PostPosted: February 27th, 2016, 17:21
Case cloused, because my black
ARCO procedure correctly goes, I'm after tests 6A, 6F, Zone TPI HeadQual, everything went without errors, mod 0C was filled with set values as more mod 03 has the correct value, as so far everything is OK.
So this error was caused by a problem FW and bad entries in the ROM. Everything works fine.
PostPosted: August 4th, 2021, 5:06
Opening up an old thread, it's the only one I could find relating to this error. I was about to ask for input, but then I solved it, posting here for anyone else who bumps into it in the future.
WD20EZRZ-00Z5HB0 came in, it would open in WD utility (PC3K) but no sector access. No SA access or ROM access. These kinds of errors:
ROM:
ROM reading............................. : HDDs ROM reading error Data request error - Device Error Detected: "CA FLUSH ALL GOT CANCELED"
ROM Firmware version.................... : Module ID 0B reading error Data request error - Device Error Detected: "CA FLUSH ALL GOT CANCELED"
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : CA FLUSH ALL GOT CANCELED
SA dir reading (ABA/CHS)................ : No S/A regions info avalable
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
I shorted TV9/10 on PCB, got into kernel mode and blocked SA access. Repowered and uploaded loader and DIR to RAM from HDD surface, reloaded utility and read all ROM, ROM mods and SA mods. All read perfectly. Couldn't see an issue. Client complained drive got slower and slower before stopping working. Heads seemed fine too.
Ran slow responding solution and reenabled SA, access, problem solved.
Data Recovery Cape Town
Users browsing this forum: No registered users and 100 guests
