Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Samsung RAID LIF 128GB SSD, any adaptor for it?????
PostPosted: August 4th, 2015, 2:07
NaelC wrote:
Dear friends,
Same problem here. Dead Sony motherboard.
Samsung MZRPC512HBFU SSD
Need to read and recover data. Need desperate help.
Thansk a ton!
If you #or anyone else# have failed motherboards but working solid state drives and want to get your data off of it, How about a trade?
I have a working VPC-Z2 with a now dysfunctional mzrpc256hadr #same thing that is used in all variants of the z2 and the svs/svz series#. Long story short, one day half the RAID array crapped out and now I'm raidless. I could buy a drive off of a really shady and expensive Chinese website, but id rather go with something that isn't as sketchy.
I can attempt to recover anyone's data and send it to you via external disks #CD/DVD, drives, whatever you want# if you let me buy the drive off of you for a reasonable price.
PostPosted: September 13th, 2015, 11:03
Hi all,
Slightly different question here, but I believe some of you may now this: Is there a way to connect a more standard SATA SSD to the 60-pin socket on those RAID-0 VAIO motherboards? Or am I stuck with the LIF SSDs on RAID forever now?
In my case it was the Samsung LIF SSD which failed. Luckily no important data there. Vaio is all fine. Would like to put a standard and more modern SSD back there. Any thoughts on how to do this?
PostPosted: September 13th, 2015, 18:32
luki wrote:
...snip.... Would like to put a standard and more modern SSD back there. Any thoughts on how to do this?
do you mean like this:
http://forum.notebookreview.com/threads/upgrading-vpc-z1-with-quad-raid-to-1tb.655886/
PostPosted: September 14th, 2015, 7:01
HaQue wrote:
No, that's way too complex, and I'm looking to connect a simple SATA drive (like this one: http://www.amazon.com/Crucial-BX100-250GB-Internal-Solid/dp/B00RQA6TEI/) in place of those RAID0 LIF SSDs. I found this cable and am thinking to give it a try: http://www.ebay.co.uk/itm/321387688269?_trksid=p2060353.m1438.l2649
Then I'll need a proper caddy for it too: http://www.ebay.co.uk/itm/131518218620?_trksid=p2060353.m1438.l2649
Just wondering if that will work.
PostPosted: December 17th, 2015, 18:50
Dear all,
I'm trying to inteface a 512Gb to SATA using info provided by Fzabkar, trying to follow the image pinout it doesn't work for me, could you post a better detail image or pinout of the image where you stroke SATA tx/rx SSD top, which one are tx and RX?
Thank you in advance
PostPosted: December 17th, 2015, 19:01
Something like this.
PostPosted: January 5th, 2016, 14:37
DR-Kiev, DR-Kiev,
Hello Dr Kiev,
I need to contact you. I have a "RAID LF128 GB MLC" SSD drive that i wish to retreive
data from.
Please contact me at martin@mat-ven.com
PostPosted: January 5th, 2016, 14:43
tckin,
Hello Tckin
I have a "RAID LF 128 GB MLC" SSD drive from a sony viao laptop whose files I want to retrieve.
Am told you had the same problem a couple of years back. Any help rendered will be highly appreciated.
Please contact me at:
martin@mat-ven.com
Thank You
Martin
PostPosted: January 5th, 2016, 15:04
Hello
Any one with an adpter for RAID LF 128 GB MLC Samsung SSD drive for sony viao laptop.
I wish to retrieve some files from this SSD drive.
Any useful info can be sent to:
martin@mat-ven.com
Thank you in advance.
PostPosted: January 5th, 2016, 17:54
I could solder wires, read your ssd like I showed in picture above.
PostPosted: March 24th, 2017, 5:04
Dear users, Does somebody now where i can get this connector or what exact name it has to order it from ebay. The pins are broken.
PostPosted: March 24th, 2017, 17:58
It's a LIF or ZIF surface mounted connector.
count pins and see what you find at mouser.com or other electronic suppliers. You may even find one on old hard disks. Fujitsu and Quantum spring to mind
https://www.mjm.co.uk/
PostPosted: March 25th, 2017, 16:29
How many pins does it normally have?
Could it be te following attachment?
PostPosted: March 25th, 2017, 16:48
Count the pins, measure the length, width and pin pitch. The check the specs for those. I think yours MIGHT be 44 pin but you will have a clearer view :)
PostPosted: March 25th, 2017, 17:08
If the broken pins are power pins, then it should be very easy to run jumper wires between the appropriate points.
PostPosted: March 28th, 2017, 8:12
How should I jumper wires?
I also don't know what the functions are of the pins.
The problem is also that I don't know how many pins there are in total.
PostPosted: April 14th, 2017, 14:50
labtech wrote:
labtech wrote:
Have one of these as well (256GB).
Any suggestions as to what NOT to do in order to avoid wasting time on such drives?
PMs are welcome if anybody feels like today is Sunday.
Thanks in advance.
Forgot to update. Was able to recover the data two days ago.
Case closed.
I appreciate the individual who sent the one PM.
I have the same problem. I have 2 VaioZs with burnt mobo and need to use those ssds in another build. So looking for an adapter to use them (not just recover data)
Please kindly help me and post the solution either in the thread or via PM. I have been searching for the past two days and a lot of the ideas are "sent in a PM". Would be great if someone can share the details publicly.
Thanks in advance.
The exact laptop model from which they was pulled off (2 x laptops): VPCZ128GG/XQ.
PostPosted: February 6th, 2018, 9:18
I have 256 GB lif SSD for VPCZ2 . Which pins should i use to connect sata? Does anyone help me?
PostPosted: February 6th, 2018, 16:32
IMHO, the easiest way to identify the SATA pins is to find an SSD with a regular 22-pin SATA connector (15 x power, 7 x data) and with the same flash controller, in this case an S3C29MAX01-Y340. Then follow the Tx/Rx traces from the SATA connector back to the controller.
http://www.storagereview.com/samsung_470_series_ssd_review_256gb_mz5pa256hmdr
http://pinoutguide.com/HD/serialATA_pinout.shtml
PostPosted: February 7th, 2018, 2:06
Think this model is a 2 x 128 GB drive. So prepare to clone 2 drives and some RAID0 reconstruction.
Digitalsupport Data Recovery
https://digitalsupport.dk
Users browsing this forum: No registered users and 58 guests
