 Post subject: WD10TMVV 11A27S2 USB drive ROM
PostPosted: January 7th, 2016, 19:13
This drive has head failure, hopefully not an issue as we have a donor. However the USB board has an integral ROM. Originally, I did manage to get the drive live on one head to extract the ROM and ROM modules. I have a matching SATA board with external ROM, but trying to write the ROM to the SATA board gives me an invalid data size error. Donor Drives have boards from this model of drive, some have external ROM's some internal ROM's. So... The SATA board I have is from a Shasta 3 drive, while the USB is Shasta. Is there generally a difference in size between internal and external ROM's? I have tried a few ROM's from different matching drives and some are the correct size which is interesting.
Invalid Data Size (197120). Expected (262144)
 Post subject: Re: WD10TMVV 11A27S2 USB drive ROM
PostPosted: January 7th, 2016, 19:18
pcb numbers?
Keep trying check board to find with same rom size or use programmator/flasher.
PostPosted: January 7th, 2016, 19:30
USB 701675-001
SATA 701672-001
PostPosted: January 8th, 2016, 1:31
Maybe you need a SATA 701609-004
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: January 8th, 2016, 12:36
you can also add 0s at the end of the original ROM File make the size 262144 bytes and try writing it. This idea was basically from "fzabkar" it is tested and worked don't remember the pcb number, hope it will help.
Data Recovery Pakistan
PostPosted: January 8th, 2016, 16:10
Yes, it will work too.
PostPosted: January 8th, 2016, 16:46
I have a 701609-001 and the controller and motor chips are both different.
I increased the size of the ROM file to 626144 with 0's (attached), but the board will not come live. I tried this with 2 ROM's with the same result. Probably need to solder a SATA connector to the USB board. Not ideal but probably the only option.
ROM_new-size.zip [179.34 KiB]
Downloaded 551 times
PostPosted: January 8th, 2016, 18:09
You have uploaded SA module 0x109. Have you been trying to write this image to your PCB as a ROM image? :shock:
PostPosted: January 8th, 2016, 19:00
If that's the case it won't work, mod 109 is missing salient information to make a complete ROM image, as fzabkar is implying.
PostPosted: January 8th, 2016, 19:53
Have a look at it yourself. The OP is writing 0x109 as is, without stripping the header or adjusting the adaptives.
PostPosted: January 8th, 2016, 20:58
Yes you are correct. My bad. I am a chump. Its been a busy day but that's not a good excuse... Here are the correct before and after (I hope). :oops:
ROM_new-size.zip [359.82 KiB]
Downloaded 633 times
PostPosted: January 9th, 2016, 14:41
Do you folks find it hard to desolder the mcu and solder it on donor boards .I find it not a hard task if you have a good tool at hand .Before i had all the toys to play around dfl,mrt and pc3k this is what i could do .BTW i am surprised .You could connect the board to the pc usb port with HSA assembly .Then wait for 15 minutes and use com port of that usb board to extract rom + rom modules [ its a piece of cake man ] .
PostPosted: January 11th, 2016, 15:34
@fzabkar. Could you take a look at the uploaded ROM and let me know if I did this correctly? Your help is much appreciated.
PostPosted: January 11th, 2016, 16:12
AFAICT the code sections of the ROM match module 0109, and the adaptive templates have been filled out, so all seems OK to me.
PostPosted: January 11th, 2016, 17:09
Many thanks. This ROM also causes the drive not to come RDY (no status register lights at all), so looks like adding zero's for this drive family doesn't work. Worth a try though.
Can you swap the mcu over from one board to another? I would have thought that with the USB board having an internal ROM, the programming/circuitry would not match with a SATA board with external ROM? But then again I have already proved in this topic that I don't know what I'm talking about :lol:
PostPosted: January 11th, 2016, 18:15
Does the drive still spin up with the original PCB?
Can you upload photos of your PCBs? There is a resistor (R74) which determines whether the MCU looks for an internal or external ROM. There is also an additional resistor which appears to be present in some implementations, but I don't understand its function.
PostPosted: January 12th, 2016, 13:11
Sorry for the later response. Here are the two boards.
PostPosted: January 13th, 2016, 5:51
The SATA PCB has an 88i9045-TFJ2 MCU whereas the USB PCB has an 88i8946-TFJ2. ISTM this may be your problem. ICBW, but I would think that the ROM code would test the processor's ID and abort if the correct processor is not present. It appears that the motor controllers are both SH6601AD, so that part is OK.
ISTM that there are two resistors that differ in the external/internal ROM configurations. According to the 2060-701640 PCB, these resistors are designated as R74 and R40. Both are present when the ROM is external, otherwise they are absent for an internal ROM. ISTM that R74 is the important one. I don't understand what R40 does.
PostPosted: January 13th, 2016, 12:01
PCB 2060-701609-000 should be compatible with this ROM
I advise you to try...
Mikippp
PostPosted: January 13th, 2016, 15:03
@ Fzabkar: Many thanks for the expert analysis as usual.
The Ace Labs USB/SATA PCB matching list is not totally correct. While the SATA board does match the USB for boards with an external ROM, they do not match for this unusual internal ROM version. The advice given above to try 701609 is correct, but needs additional info. I didn't have a 2060-701609-004 (and cannot find that board on Donor Drives), so I looked at a 2060-701609-001 which I had in stock, but the controller didn't match which threw me off the trail a little. However after doing more research and Mikipp's advice, I have found the correct board (see below).
PCB Sticker: 2061-701609-800 03P
PCB Revision: 2060-701609-000 REV P1
Controller Chip: 88I8946-TFJ2
So for anyone that reads this, if you are matching the USB PCB 2060-701675-001, if its an internal ROM check the controller as you may need the above board instead.
Users browsing this forum: No registered users and 62 guests
