 Post subject: Need Firmware - WD10JPVX-75JC3T0 [ ROM-0016000T ]
PostPosted: January 7th, 2016, 9:51
Hello Friends ,
Need Complete ROM + ROM Modules + SA Modules For this Drive .Seems To Be FBlite [ WD10JPVX-75JC3T0 ] 1TB 2.5" Blue HDD .My PC3K Log For Reference .I Read Somewhere that SPT is 1437 For These and Not 1480 [ Can Someone Please Confirm .
PC 3000 [ Log ]
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 185 150
SA regions address...................... : by default
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 16.0TG
ROM F/W version......................... : 0016000T
Overlay F/W version..................... : 16.0TG
Servo F/W version....................... : N0.18
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : NONE
Configuration reading................... : No SA copy avalabled
PS : Thank To All in Advance
 Post subject: Re: Need Firmware - WD10JPVX-75JC3T0 [ ROM-0016000T ]
PostPosted: January 7th, 2016, 10:11
Just have backup for : WDC WD10JPVX-00JC3T0-01.01A01.
PostPosted: January 7th, 2016, 12:56
HERE YOU GO
This PCR for 0016000T
http://www.4shared.com/rar/3Mhu-figba/W ... 01A01.html
BTW : your SPT here 1437
GOOD LUCK
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: January 7th, 2016, 13:07
http://files.hddguru.com/download/PC-30 ... 3C2588.rar
PostPosted: January 7th, 2016, 13:49
Hi ,
Thanks Tomset ,Tawfek and Ahmed .Will Try It Out and Let You Know
PostPosted: January 8th, 2016, 5:32
Hello All,
Tawfeek it was good talking to you .Your Mod 11 Worked .This is the Structure Test Of this Patient HDd .Mod 11 Copy 0 and 1 Gone , Module 33 Plist Copy 0 and 1 Gone , Module 31 Translator Gone Copy 0 and 1 , Module 004E Gone Copy 0 and 1 Not Sure If Its Important [ Possible its a overlay code too ] , Module 002d Gone [ Copy 0 and 1 ] , Module 006F Gone Both Copies [ Not Important IMHO ] , Rest 0121 , 0120 , 34D5 , 3430 , 34D1 , 34D6 , 00D7 , 00D9 , 00BC , 3504 , 00C5 , 241F , 2D13 , 2D03 , 2FF0 , 2D04 , 2D20 , 2520 , 26D1 , 26D3 , 2D08 , 2671 , 2680 , 2D14 , 2514 , 2D1E , 2D0B , 00B5 , 2D1F , 2D0C , 250C , 00E2 , 00E3 , 2D0A , 2D1D , 251F , 2D22 , 2D29 , 2529 , 00E8 , 2D0E .Other Modules Have Atleast 1 Copy Working .Also Module 004 Is Not OK [ but i Can Borrow This ] . I Have a Plan To Recover this But Would Like you All also To Please Gimme your Experience in This . If someone is interested to know my plan i can pm him .
New Text Document.txt [127.75 KiB]
Downloaded 878 times
PostPosted: October 1st, 2016, 13:42
Hi Amarbir (viewtopic.php?f=1&t=32671&p=227351&hilit=WD10JPVX+no+ID#), I had the same/similar problem. Here is my PC3K output:
Techno mode key
RAM:
ROM:
ROM reading............................. : Ok
Modules directory address............... : 184 391
ROM Modules:
ROM version............................. : 16.14G
ROM F/W version......................... : 00160014
Overlay F/W version..................... : 16.14G
Servo F/W version....................... : NA.18
Service area:
I am curious if you solved this problem?
Users browsing this forum: Google [Bot] and 37 guests
