 Post subject: HITACHI HCS5C1010CLA382
PostPosted: January 12th, 2016, 10:57
Hey guys, this HITACHI hdd has a dead PCB.
Later at lab I'll try to dump ROM via MRT, but meanwhile I'd like to know how much would I spend on a PCB for this drive.
MLC: JPC3EA
FW: 3EA
Disk is from April 2010.
The pcb sticker shows: 0A72937 | BA3321B | M6H012 | D73A
What kind of requirements does the donnor PCB needs to fill ?
Thanks.
 Post subject: Re: HITACHI HCS5C1010CLA382
PostPosted: January 12th, 2016, 11:37
model, first 2 lines from sticker
PostPosted: January 12th, 2016, 11:57
This ones right ?
Donor pcb must be from a disk with the same size also correct ?
PostPosted: January 12th, 2016, 12:08
This is the pcb I will buy, all the numbers match, however this pcb is from a hdd with 320GB capacity and not 1 TB.
PostPosted: January 12th, 2016, 12:17
would you mind uploading a pic. from the patient's PCB ?
PostPosted: January 12th, 2016, 14:17
Here's the patient pcb
PostPosted: January 12th, 2016, 15:44
i can't read it
PostPosted: January 13th, 2016, 5:30
Can somebody upload NVRAM
Model : HDS5C1010CLA382
MLC : JPC3MA
FW : 3MA
PostPosted: January 13th, 2016, 6:31
MLC : JPC3MA
FW : 3MA
that's the exact disk I have here.
PostPosted: January 13th, 2016, 6:36
can you upload the NVRAM and ROM
PostPosted: January 13th, 2016, 6:49
MLC : JPC3MA
FW : 3MA
Here.
nv-ram.rar [9.29 KiB]
Downloaded 540 times
PostPosted: January 13th, 2016, 17:17
Donor pcb is compatible.
PostPosted: January 13th, 2016, 21:22
I'll order it then.
I've also tested the diodes, they were not showing correct values, so I removed them and attemped to power on the disk via MRT but without sucess.
I assume that someone without ultra experience in electronics wont be able to check anything more then diodes on a disk pcb right ?
What should I test after the diodes ?
PostPosted: January 13th, 2016, 22:53
You can perform some basic measurements.
I would start by testing the 0.1 ohm resistors adjacent to the TVS diodes.
Next I would check the Vcore, Vio and -5V test points.
PostPosted: January 14th, 2016, 8:54
Thank you frank for your help, Im gonna check it out as soon im back at lab
PostPosted: January 14th, 2016, 11:38
all measures are correct, I'll order the freaking PCB and get on with it.
PostPosted: January 14th, 2016, 15:14
If the 0.1 ohm resistors are intact, and if either of the TVS diodes were shorted, then the drive should have shut down your PSU.
If "all measures are correct", then could it be that PUIS is enabled? If so, then a tool such as HDAT2 will allow you to disable PUIS.
BTW, the NVRAM checksum appears to be correct.
C:\>xorchksm -16 nv-ram.nvr
nv-ram.nvr: XOR16 checksum = 0x0000
PostPosted: January 15th, 2016, 7:19
PUIS is not enabled, already checked :/
Users browsing this forum: Bing [Bot] and 36 guests
