 Post subject: FBLite LDR for 0016001C needed - WD10JMVW-11AJGS2
PostPosted: January 12th, 2016, 16:55
I need LDR (and modules / tracks if possible) for the following Fblite:
Model: WD10JMVW-11AJGS2
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 111 275
SA regions address...................... : by default
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 16.56H
ROM F/W version......................... : 00160056
Overlay F/W version..................... : 16.56H
Servo F/W version....................... : N0.38
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Thanks in advance!
-BR-
 Post subject: Re: FBLite LDR for 0016001C needed - WD10JMVW-11AJGS2
PostPosted: January 12th, 2016, 21:33
Different MDL, but same family.
http://files.hddguru.com/index.php?acti ... ty/Fblite&
Users browsing this forum: No registered users and 95 guests
