Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD10TMVV 11A27S2 USB drive ROM
PostPosted: January 13th, 2016, 16:24
ISTM that the logical approach would be to match the MCU and motor controller. A USB PCB is just a SATA PCB with a USB-SATA bridge glued to the front end. Therefore it stands to reason that the two PCBs should be essentially identical after the SATA interface.
PostPosted: January 13th, 2016, 16:28
You are correct. Its was just laziness on my part using the Ace Labs list as it has always been correct before.
Users browsing this forum: Google [Bot], pepe and 42 guests
