 Post subject: ST3500830AS Media Cache Disable???
PostPosted: January 14th, 2016, 4:39
How to Disable Media Cache in ST3500830AS (7200.10)
I got T prompt T>
When i Cleared G-List, i can clone hdd at nominal speed, but after 10 to 15 again slowed down
then checking G-List entries added, Then i have clear again then continue to clone
How to disable reallocation here
i tried
T>F"RWRecoveryFlags",00,22
SetStuff->
Here what i have to do?
sorry for my poor english
 Post subject: Re: ST3500830AS Media Cache Disable???
PostPosted: January 14th, 2016, 8:56
Any commands to stop background scanning and stop reallocation for 7200.10?
PostPosted: January 14th, 2016, 13:12
You are using F3 drive architecture commands on a classic architecture drive. Does it make sense doing so?
PostPosted: January 15th, 2016, 0:45
Nothing happened. when i issue the command it only display just "SETSTUFF-->"
there may be some commands to disable media reallocation for 7200.10 Series.
Pls share anyone
PostPosted: January 17th, 2016, 10:08
Use a loader if it's not F3
Data Recovery Cape Town
PostPosted: January 20th, 2016, 14:55
you are sure that the disk has this problem?
In the terminal should look something like,
"CE Log ErrCode=xx LBA=xxxxxxx Type=5 Add To Pending xxxxxxx"
If there (CE log err), but dangerous if the disk has other problems....
Users browsing this forum: Google [Bot] and 227 guests
