 Post subject: WD30EZRX-00AZ6B0 Firmware
PostPosted: January 16th, 2016, 10:13
I have a WD30EZRX-00AZ6B0 Harddrive , it spins up and Head noise are normal.
After a reboot the Drive is not recognised in the Bios (PC and Cables are OK)
What can I do ?
MHDD ???
 Post subject: Re: WD30EZRX-00AZ6B0 Firmware
PostPosted: January 16th, 2016, 16:51
Are you saying that the drive always shows up during an initial boot but then disappears after a reboot? Or do you mean that the drive was working until the last boot attempt and is now dead?
PostPosted: January 16th, 2016, 18:16
I mean that the drive was working until the last boot attempt and is now dead.
Drive dont shows now up at all.
PostPosted: January 16th, 2016, 18:27
Sounds like head problem on head 0 (at least).
http://www.rescue-it.se
PostPosted: January 16th, 2016, 18:37
Well, I don't think the problem is the Head 0 and 1.
This problem propably FW, BSY state, slow reponding. Permanenlty on highest drives Up 2TB, 3TB, etc.
PostPosted: January 17th, 2016, 4:46
after seconds slightliy clicking Sound
PostPosted: January 17th, 2016, 7:36
A colleague sure that what you hear is a clicking heads?
PostPosted: January 17th, 2016, 8:22
Spins down ?
PostPosted: January 17th, 2016, 8:27
If the problem is slow responding bios would picked it up...
Now 100% sure of head damage...
This is not a DIY job, if the data is important take the drive to a data recovery center.
PostPosted: January 17th, 2016, 9:04
Ok, but Let the author of check PCBs, and clean up oxydation HSA pinout, Because maybe too early prognosis damage the heads.
Look: http://www.hddoracle.com/viewtopic.php? ... lean#p1789
PostPosted: January 17th, 2016, 9:33
It does not spin down, Contacts are cleaned.
PostPosted: January 17th, 2016, 15:10
Intresting, Propably, slow responding or head map in ram error. What tool you using? PC3K or DFL etc?
PostPosted: January 17th, 2016, 16:30
I have no Special Equipment
PostPosted: January 18th, 2016, 4:26
Most likely this isn't a DIY job if you don't have any professional tools.
If you are willing to go down the road of professional data recovery and the data is important, we can take a look at it for you.
We don't charge evaluation and pick up the drive for free in Germany.
Feel free to contact me if you would like.
Regards,
Web: https://www.day1data.de
PostPosted: January 18th, 2016, 11:39
+1 for day1data :-)
