 Post subject: 500GB WD HDD blue desktop drive difficult to access when sla
PostPosted: January 19th, 2016, 7:33
I have a faulty WD drive that takes like 2 hours to boot up systems and after booting it takes another hours to check/work on the drive through moving around the systems.
Any software i try to use to help out takes ages to come up. The drive partition has disappeared but when clicked on the disk management it comes up after several hours with 1. Disk partition capacity 2. Unallocated space 3. Do you want to initialize the disk.I tried using Easeaus software but when i chose the complete recovery option --- the hdd capacity reduces to 116mb but when i chose the partition recovery the total disk capacity displays 500GB and then i satrted the scanning.... because of the slowness of the HDD it doesnt change a thing even after 6 hours ...
I received the below when scan through a recovery tool;
There is an error in reading tracks:
Read Track error C/H/S: -252/1/991
Read Track error C/H/S: -252/1/992
Read Track error C/H/S: -252/1/993
Read Track error C/H/S: -252/1/994
Read Track error C/H/S: -252/1/995
Read Track error C/H/S: -252/1/996
Read Track error C/H/S: -252/1/997
Read Track error C/H/S: -252/1/998
Read Track error C/H/S: -252/1/999
Read Track error C/H/S: -252/1/1000
Read Track error C/H/S: -252/1/1001
Read Track error C/H/S: -252/1/1002
Read Track error C/H/S: -252/1/1003
Read Track error C/H/S: -252/1/1004
Read Track error C/H/S: -252/1/1005
Read Track error C/H/S: -252/1/1006
Read Track error C/H/S: -252/1/1007
Read Track error C/H/S: -252/1/1008
Read Track error C/H/S: -252/1/1009
Save track : 0252 - 1 : ........................: ERR(Read Fail)
I will be glad if anyone can help me out here.
Taiwo
 Post subject: Re: 500GB WD HDD blue desktop drive difficult to access when
PostPosted: January 19th, 2016, 8:55
sounds like slow responding issue
or weak/bad heads
PostPosted: January 19th, 2016, 9:15
Hello Jerny,
Thanks for your input. What do i use to resolve a slow response issues like this ?
Taiwo
PostPosted: January 19th, 2016, 9:38
if you have at your disposal expansive tools like PC3K, DDI Etc., it's one click solution
if not... WD - Fixing the "Slow Issue" manually
PostPosted: January 19th, 2016, 13:13
HDDSuperTool has a script to do this for you. Try the mod02 script first.
http://www.sdcomputingservice.com/hddsupertool
http://www.sdcomputingservice.com/hddsu ... ects=0&d=1
Users browsing this forum: No registered users and 141 guests
cron
