 Post subject: Seagate Thin Head Compatibility
PostPosted: January 29th, 2016, 7:35
I have a Seagate Thin (ST500LT012) with head problems. Surfaces not damaged.
I replaced the heads already with 2 sets of heads from compatible donors:
Model number mach
Serial number: Match the second and third characters
Heads map: Match the physical heads map exactly.
Part number: Match the 1st half and 2nd half of the part number.
Site code: Match the site code
Date code: 6 months and 3 months difference
But heads continue without reading disk.
Any "special" features about these drives that I do not know?
Thanks,
 Post subject: Re: Seagate Thin Head Compatibility
PostPosted: January 29th, 2016, 9:26
Thanks,
here is the problem i think, try matching first 3 characters.
Data Recovery Pakistan
PostPosted: January 29th, 2016, 17:19
MindMergepk wrote:
Thanks,
By matching the site code, the first should be matched :-)
Do the heads work fine back in their respective donors (both heads)?
PostPosted: February 1st, 2016, 6:49
Thanks for the suggestions.
Heads work fine back on the donor.
Users browsing this forum: gps31 and 60 guests
