 Post subject: Toshiba head compatibility
PostPosted: February 3rd, 2016, 9:37
Hello!
I want to know if this donor drive matched for this patient drive.
Donor : MK5076GSXN
PCB : G002706
Patient : MK5061GSY
PCB : G002822A
Thanks in advance.
 Post subject: Re: Toshiba head compatibility
PostPosted: February 3rd, 2016, 11:15
Case solved.
Thank you. :)
PostPosted: February 3rd, 2016, 12:02
And the answer to your question was?
PostPosted: February 3rd, 2016, 12:34
Yes.
Fully matched. :)
PostPosted: February 3rd, 2016, 12:45
Thanks for the info
PostPosted: February 3rd, 2016, 12:48
jermy wrote:
Thanks for the info
Always welcome. :)
PostPosted: February 3rd, 2016, 13:03
I must admit, I wouldn't have thought it to work simply based on the model number...though, I probably would have tried too if I didn't have a closer match.
PostPosted: February 3rd, 2016, 13:15
Agree. But I believe that Toshiba is the most friendly drive in head/s replacement. :)
So, I did the heads change. (4 heads)
Imaged successfully 100% ( 5 bad sectors all ) :)
Copying the data now to the customer drive.
PostPosted: February 3rd, 2016, 13:22
+1 most tolerant HDD
Congrats
