 Post subject: Can I use SSD as external backup on 1 USB 2.0 port?
PostPosted: February 3rd, 2016, 7:31
Hi guys,
I plan to buy a 2.5" 256GB Solid State Drive and use it as external backup storage.
Because SSDs don't have moving parts I hope that the power from 1 USB 2.0 port (500 mA) will be enough to use the SSD without any problems, but I am not sure so I wanted to ask you guys if this is possible.
Can 1 USB 2.0 port (500 mA) provide enough power to use a 2.5" 256GB SSD without any problems?
And can you guys recommend me a 256GB SSD for external backup storage that uses low power and is nicely built and durable to last longer?
Thanks for your time.
 Post subject: Re: Can I use SSD as external backup on 1 USB 2.0 port?
PostPosted: February 3rd, 2016, 8:33
Why you want to use slow USB and fast SSD? You have USB3.0 10x faster then USB2.
For good SSD search on other PC hardware forums.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: February 3rd, 2016, 11:57
Hi, thanks for replying.
I already have 1 USB 3.0 Flash Drive, and I wanted to buy 1 more for security.
But I read somewhere that Solid State Drives have a bit better quality and have longer durability than USB Flash Drives. Is this true?
That is why I was considering to buy a Solid State Drive for backup instead of another USB Flash Drive.
PostPosted: February 5th, 2016, 15:13
I want to ask you guys 1 more thing, I plan to fill the full 256 GB device with data and then let it sit powered off for 5-10 years if possible.
Which would be the best to use for this situation: USB Flash Drive, Solid State Drive or normal Hard Disk Drive?
PostPosted: February 6th, 2016, 5:23
Don't expect it to be a certain thing that single USB 2.0 is enough to power an SSD. For ancient models like Intel X25-M G1 (2.5W) it is just enough, but for an OCZ Trion 100 (4.8W), not even a single USB 3.0 is sufficient. Not to mention that the SATA bridge on the USB adapter might matter too.
Indeed an SSD probably has a higher endurance than a simple thumb drive, but that might not matter a lot if the data are gonna be static for years.
I heard that flash memory cannot hold data for too long without power too, but I don't know exactly how often you need to "charge" it. You can't be bothered to at least connect it to power once a year or so?
But to be honest, HDD seems to suit your case most.
PostPosted: February 8th, 2016, 2:41
[quote="we3fan"]I want to ask you guys 1 more thing, I plan to fill the full 256 GB device with data and then let it sit powered off for 5-10 years if possible.
I wouldn't use a flash device for this. I would probably use a HDD or 2, being so small and cheap and if data was extremely important, cloud storage as well.
Users browsing this forum: Majestic-12 [Bot] and 61 guests
