Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Advice on recovery for a WD My Passport 2TB USB drive
PostPosted: December 28th, 2015, 1:32
thatdellguy wrote:
koitsu wrote:
We can consider this matter closed and a success. "Like watching a bad movie with an ending you can predict" -- I guess that means he predicted success even though the film wasn't worth watching. ;-)
"Don't believe everything you read on the Internet as true"
Before ...
4 Start_Stop_Count -O--CK 100 100 000 - 91
9 Power_On_Hours -O--CK 100 100 000 - 102
12 Power_Cycle_Count -O--CK 100 100 000 - 65
192 Power-Off_Retract_Count -O--CK 200 200 000 - 52
193 Load_Cycle_Count -O--CK 200 200 000 - 54
After ...
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 101
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 115
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 74
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 61
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 148
13 Power On Hours and 9 Power Cycles for a drive that was "catatonic" sounds fairly conclusive.
If the OP wants to play with the drive after he has completed the data recovery, we can provide irrefutable proof of the drive's status. This would involve dumping the drive's firmware modules, reading all 2TB of its capacity, and then dumping the modules again.
PostPosted: December 28th, 2015, 10:14
Congratulations! I under-estimated you.
http://www.datasaversllc.com
PostPosted: December 28th, 2015, 10:47
Spildit wrote:
This means that now we can do the slow fix and read/write modules and ROM on WD drives that are USB only by HDDSuperTool bypassing the USB bridge chip.
I would just like to point out that it depends on the USB bridge. Some will not process the vendor specific commands, and sometimes even react funny to regular commands. So it cannot be claimed to always work.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: December 28th, 2015, 14:51
From ddrescue's final report ...
    (2000 GB) / (69,733 kB/s) = 7.97 hours
It would be nice to have a script that parsed mod01, identified all the module IDs and their sizes, and then retrieved each of them.
PostPosted: December 28th, 2015, 17:51
You mean like this? :D
PS The whole point of the scripting tool was so that OTHERS could write scripts to do the things they wanted :wink:
wd_royl_dump_mod_all.txt [7.14 KiB]
Downloaded 1688 times
PostPosted: December 28th, 2015, 18:02
Thanks very much. Yes, I have every intention of writing my own scripts for HDDSuperTool. I just need the occasional motivation. :-)
PostPosted: December 29th, 2015, 13:03
That the Worthiest post, I ever read it for this kinda HDD
Expect, the Unexpected
PostPosted: January 31st, 2016, 10:24
koitsu wrote:
Oh my... it's working after the mod02/mod32 patch! The drive didn't go into a catatonic state, and I/O appears stable so far:
GNU ddrescue 1.17
About to copy 2000 GBytes from /dev/sdb to /dev/sdc
    Starting positions: infile = 0 B,  outfile = 0 B
    Copy block size: 128 sectors       Initial skip size: 128 sectors
Sector size: 512 Bytes
Press Ctrl-C to interrupt
rescued:    16818 MB,  errsize:       0 B,  current rate:     119 MB/s
   ipos:    16818 MB,   errors:       0,    average rate:   98929 kB/s
   opos:    16818 MB,    time since last successful read:       0 s
Copying non-tried blocks...
/dev/sdb = origin drive (now patched)
/dev/sdc = destination drive (same capacity, slightly more LBAs, same sector size)
I'll let this run and see what the result is in the morning.
Seems like I have exactly the same issue with WD Elements WDBUZG0010BBK-03.
Slooooow detection under OS, lags, unable to copy, Imaging transfer ca. 60kB/s (44days to complete).
Did you have to replace te PCB or you were able to clear/fix 02 and 32 through USB ?
PostPosted: February 8th, 2016, 1:41
koitsu wrote:
Well, I have a way to keep the drive "alive" for longer periods of time, but it does appear that reading certain LBA ranges cause the drive to go into a catatonic state. From my review of my data, I'm thinking these regions are calculable.
I believe this supports fzabkar's theory that there may be a specific head that's misbehaving or wonky. The drive has 4 platters with 8 logical/physical heads.
The bright side is that with my workaround, the successful I/O period is substantially longer, allowing me to try the mod02/mod32 patch without too much worry. I'll give that a shot. I'm hoping that might make the overall drive behaviour on failures/retries/etc. "better" for something like ddrescue.
Dear koitsu,,
I'v similar drive has the same problem, in your case you'r say " you have a way to keep the drive "alive" for longer periods of time,"
Can you tell me how you do that, to apply this in my case?
PostPosted: February 8th, 2016, 9:34
Dear koitsu,,
update
Today, I tried patches mod02 and mod32 by HDDsupertool, and I successed to patche it, it become more faseter
But when I tried to clone it by DDrescue, it read some sector and conn't read other, it's that indicate there is head sick?
PostPosted: February 9th, 2016, 1:20
Spildit wrote:
Most likely one of more of the heads are gone.
You will need proper tools to clone the drive with the good heads if that is the case and using USB interface doesn't help as well.
Did you try to do a reverse clone ?
On drives with the slow issue that i've clones (with hardware assisted cloning tool) ALL of them had patches of bad sectors on some point on the platter. Maybe you have hitted some bad sectors but maybe you can clone on reverse or skip the bad area.
If the problem is indeed with one or more heads either you live without the data on that platter or you have to send the drive in for data recovery to a proper data recovery firm (not a regular computer repair shop) with a proper aseptic hepa 100 room or laminar flow workbench.
Now, I'm doning "forward" normal clone by DDrescue, and then, I'll try to make reverse clone, I hope that success
If that failed, I'll try to convert PCB to SATA, and image it by "DC", if give me the same results, there is a problem in one or more head, but if I can image it by SAtA PCB, the image will be encrypted, and I'll face new problme "How to decrypt the data"
because, I don't have the proper tool to decrypt the data.
PostPosted: February 9th, 2016, 7:11
If the problem is head(s), converting to SATA is not gonna help you
anyway, do not clone partial by USB and partial by SATA
regarding the encryption, upload a clear pic. of the PCB or write the chip marking
PostPosted: February 9th, 2016, 9:48
I know that it's give me the same result as well as the data will be encrypted.
I'll upload a pic tomorrow, the HDD is not beside me now :(
PostPosted: February 10th, 2016, 2:55
this is the pic for HDD and chip
PostPosted: February 10th, 2016, 9:02
if you convert to SATA, then clone it to another WD
1) make sure they have the same LBA's
2) 4061-705094 uses the same chip and able to decrypt the data
PostPosted: February 14th, 2016, 7:36
the pic after finish clone:
it's clone about 75%
PostPosted: February 14th, 2016, 14:24
First, I see you did it wrong, you have to clone the entire drive I.e.
ddrescue <parameters> /dev/sdc /dev/sda <logfile>
not a partition (sdc1).
Second, with that size of error , I would have considered to clone it with hardware (I assume you'll have a lot more data out).
PostPosted: February 14th, 2016, 16:21
75% looks like good data from 3 heads (748GB), and one bad head with no data (252GB, and last successful read was 1.1 days ago). 25% of the data is toast unless you take it to a professional that is capable of replacing heads. I don't see any more do-it-yourself for that drive.
Also, as jermy pointed out, you might have a bit of extra trouble working with the recovered disk since you cloned a single partition to a whole drive.
PostPosted: February 15th, 2016, 1:35
Thank you for your replies
I'll reclone it by your recmmandation.
After get the most data, I'll see what I can do for a sick head.
PostPosted: April 4th, 2017, 17:01
I can help you with decrypting the data, if you still need. I know how to set up a
decryption filter using cryptsetup in linux.
Users browsing this forum: No registered users and 51 guests
