 Post subject: WD Esprit LDR needed 00090030
PostPosted: February 10th, 2016, 7:46
WD5000BPKT-00PK4T0...
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 3
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 512 Kb
Flash ROM dir reading................... : Ok
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 09.30D
ROM F/W version......................... : 00090030
Overlay F/W version..................... : 09.30D
Servo F/W version....................... : SM.1V
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 3
Switched off heads...................... : Yes
Heads map............................... : 0,2,3
Cheers! :-)
 Post subject: Re: WD Esprit LDR needed 00090030
PostPosted: February 10th, 2016, 8:05
here it is .......
http://files.hddguru.com/index.php?acti ... ty/Esprit&
PostPosted: February 10th, 2016, 13:40
Thanks guys.
I have the LDR now, but it seems this drive has more serious issues too :-(
PostPosted: February 10th, 2016, 13:48
Scratches to the surface or similar?
PostPosted: February 10th, 2016, 14:43
Don't think so, sounds pretty normal and platters look in good shape and no bent heads.
But either the heads are suspect/weak or the SA is pretty unhealthy, awaiting client approval of costs before proceeding any further.....
PostPosted: February 10th, 2016, 16:08
Got it.
Good luck Mr. Sean.
Users browsing this forum: No registered users and 97 guests
