 Post subject: HDDSuperTool
PostPosted: February 22nd, 2016, 2:56
HDDSuperTool is an advanced Linux based hard drive utility tool. It is script based, meaning it runs scripts for its functions.
http://www.sdcomputingservice.com/hddsupertool
Phoenix Computer Forensic Laboratory
http://www.databack.ir
 Post subject: Re: HDDSuperTool
PostPosted: February 24th, 2016, 12:56
Hi !
After installation on Debian 8, running produces the following message:
GLIBC_2.4 not found
PostPosted: February 24th, 2016, 13:01
try this:
sudo apt-get install glibc
or
sudo apt-get install libc6
That should add the needed dependency. You also might need to run "sudo apt-get update" first.
PostPosted: February 24th, 2016, 13:06
shall I restart debian after the apt-install ?
Note I run wheezy (sorry my first message was wrong) from an old disk in order to repair a new one :(
/lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by hddsupertool)
PostPosted: February 24th, 2016, 19:48
Ok. I made apt-get upgrade to upgrade my old wheezy.
Now libc.so.6 is here but the version is 2.13 for glibc
I downloaded libc6_2.19-1_amd64.deb from sid and executed dpkg -i --auto-deconfigure ...
Now hddsupertool start but finds only one disk:
Finding devices
Q) Quit
R) Refresh drive list
1) /dev/sda WDC WD1502FYPS-02W3B0 WD-WCAVY4851994
Choose which drive >
PostPosted: February 25th, 2016, 21:13
Finding devices
Q) Quit
If you do a command such as "fdisk -l" does it list any more disks?
To find disks in the normal mode HDDSuperTool uses the following command to make its list:
"ls /dev | grep -w sd."
This will list all devices that start with "sd" and are 3 characters in length. If you can list the disk with another command, you can use the -t (-- target) option to choose the disk manually.
HDDSuperTool is built using Ubuntu (actually xUbuntu) 14.01. I have tested back to Ubuntu 10, and also some Fedora versions. Ubuntu is Debian based, so I am surprised it it has issues running on another Debian system.
http://www.hddsuperclone.com
Home of HDDSuperClone
Users browsing this forum: Bing [Bot] and 105 guests
