 Post subject: LDR for WD2500AAJB-00WGA0
PostPosted: February 23rd, 2016, 13:07
anyone out there having such a LDR? :=)
ROM FW is 005800AA - Firmware i can not read out.
I think it's head damage (Because also scratches on disk) - but i'll try - with Files from database (it's not compatible)
 Post subject: Re: LDR for WD2500AAJB-00WGA0
PostPosted: February 23rd, 2016, 13:25
FW should be 58.AAD
Headmap is 0,1,2.
maybe also someone having such a disk and can send it with Express? :)
PostPosted: February 23rd, 2016, 13:32
outbreak198x wrote:
Headmap is 0,1,2.
you sure ? here is written otherwise, 0,1,3
they can provide you a LDR (and resources) and they will ship it to you too :)
PostPosted: February 23rd, 2016, 13:35
Are:
WD2500AAJB-00WGA0-00.02C01-(58.AAD)-WCARY
WD2500AAJB-00WGA0-58.01H58-(58.AAH)-WCAS2
PostPosted: February 23rd, 2016, 14:43
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 3
Cyl Count............................... : 128
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 192 Kb
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 1
ROM Modules:
ROM version............................. : 58.AAD
ROM F/W version......................... : 005800AA
Overlay F/W version..................... : 58.AAD
Servo F/W version....................... : 01.0L
Heads configuration..................... : by map
Heads number in use..................... : 3
Switched off heads...................... : No
Heads map............................... : 0,1,2
OK thx now i found it :=)
but think it's dead...
PostPosted: February 23rd, 2016, 14:50
http://files.hddguru.com/download/PC-30 ... 959215.rar
PostPosted: February 23rd, 2016, 15:46
Great thx, i booted up set 0 2 2 in RAM MAP - so it spins :)
loaded LDR, read out modules, reboot, load again 0 2 2 otherwise not possible, loaded my LDR . read out data from h0 nearly 100%, now i've to come near headcrash :D on 1+2
