 Post subject: Problem with Toshiba
PostPosted: February 25th, 2016, 7:52
i have a Toshiba MK7559GSXF with strange sound between click, ( attached mp3 ). i have a clean room but before order a donor im not sure if this strange sound can be only head problem or other, after open disk to inspect i not see anything strange on platter. Any Advice? Thanks!
25 feb 12.45.zip [189.09 KiB]
Downloaded 337 times
 Post subject: Re: Problem with Toshiba
PostPosted: February 25th, 2016, 9:28
first, it doesn't have to be the platters it can be the HSA
second, i assume you only inspect 1 side of the platter (the top one) out of 4 (2 platters = 4 sides)
PostPosted: February 25th, 2016, 9:52
Ok, yes i inspect only first plate, im not able to inspect other ( never do that). You think the strange sound noise can be HSA? Also, if usefull, drive was correct ricognizione by BIOS and with correct capacity from system after about 2 minute when click stop but nothing can be read. Thanks
PostPosted: February 25th, 2016, 16:09
Sounds like internal read-write component problem. Firmware is likely problematic as well.
Need a better diagnosis by a specialist with knowledge and advanced tools.
Users browsing this forum: No registered users and 102 guests
