 Post subject: Need help with WD10EAVS drive
PostPosted: February 24th, 2016, 20:21
Hi all.
So, I was asked to try and recover data (years and years of family photos) from a friend's HDD. I was told that it stopped working after a power spike. She took the drive to a computer repair shop, but they asked over 1500€ for the service.
This is the drive's info:
MDL: WD10EAVS-00D7B1
WWN: 50014EE1AC4277BA
DATE: 20 FEB 2009
DCM: HARNHT2MAN
LBA: 1953525168
I plugged it on my computer and booted the machine. The drive started spinning and clicked as expected, but then just stopped. I confirmed the motor had stopped by measuring voltage on its connectors - it was 0V all around.
In the meanwhile I had entered the BIOS and got this:
Unsure of how to proceed, I shut the computer down, removed the drive and started searching online. I found various mentions to a possible PCB failure, or of one of its components.
Tested diodes D3 and D4 with a multimeter, they worked as expected. Been thinking of getting a new PCB to swap (with the same codes as the previous image), but there's no chip on U12, so my life's not easy on that avenue either - from what I'm reading the firmware is located on teh Marvell chip, correct?
Right now, I'm not exactly sure how to proceed, as I lack the tools to properly swap the Marvell chips between boards. I've been given a contact of a technician that has those tools, and often does work for a local computer shop in repairing motherboards and graphics cards... so that's a possibility.
Anyhoo, what do you guys think? Should I go ahead with the PCB idea? I also heard of a live-swap/hot-swap procedure... from my limited understanding this is simpler than the whole soldering/desoldering process, but would it work? I just need the drive to work long enough to copy the data to somewhere else.....
 Post subject: Re: Need help with WD10EAVS drive
PostPosted: February 25th, 2016, 8:03
Most Probably Problem with Heads changing PCB or Live Swap wont help you if Data is important give it to Pro. Good Luck..........
PostPosted: February 25th, 2016, 10:21
Well... wouldn't I get loud clicking sounds on boot if that was the case? Kinda like in the 2nd link here:
http://www.datacent.com/hard_drive_sounds.php
PostPosted: February 25th, 2016, 14:48
Agree, PCB swap or "live swap" will NOT help you at all and potentially make things a whole lot worse.
I must say though, €1500 does sound very steep :-(
Unless there's more serious underlying issues (e.g. platter damage)
PostPosted: February 25th, 2016, 15:40
Most often when WD Marvel series drives have a blown PCB you'll get absolutely nothing, no spin up, no clicks, nothing. The fact that it is spinning up and back down, I'd say there's about a 0.001% chance the problem has anything to do with the PCB. So I wouldn't waste the time or take the unnecessary risk trying to replace the PCB. It's almost certainly either failed read/write heads or service area damage and will need to be handled by a professional.
Since you're in Portugal why not send it to PCLab http://www.pclab.com.pt/
PostPosted: February 26th, 2016, 11:02
Thanks for the replies, you were really helpful - I was really hoping it would be something I could fix on my own and spare my friend a hefty bill, but I guess we weren't that lucky.
pcimage, this is just for my personal curiosity's sake: wouldn't platter damage cause scratching noises during the spin up/down of the HDD? Or is that something that can only be identified when opening the HDD's case? (don't worry, I won't do it :) - as I said, just personal curiosity )
data-medics: Thanks for the link, I wasn't aware of that store. I'll pass it along, hopefully they'll be able to help. :)
Users browsing this forum: No registered users and 68 guests
