 Post subject: PC lagging (Disk usage either 100% or 0%) except in Safe mod
PostPosted: March 1st, 2016, 21:35
Running windows 10...
I started getting the disk check at startup for D: partition which would usually take long and recur everytime I restarted the PC, so I started skipping it.
Then, the PC started getting stuck at and after the log-in screen to the extent that now even a video stored on the PC requires buffering after every few minutes running on VLC or opening a folder takes minutes and the taskbar gets stuck... Don't ask!
Now, its worse, the computer is pretty much NOT usable in Normal mode...
I started the PC in Safe mode and the PC is running fine, Everything is Fine! I ran disk check (using command prompt) for C:, it found some errors but ran smoothly & was quick at bootup after restarting, however, the disk check for D:, which ran while in safe mode, got stuck at "chkdsk is verifying usn journal…” :(
There has been a slight noise from the HDD but that has been there since I bought the laptop three years ago...
What do you guys think, is it a virus or is my hard disk failing :?: :?: ???
 Post subject: Re: PC lagging (Disk usage either 100% or 0%) except in Safe
PostPosted: March 2nd, 2016, 2:43
It's your hard disk failing.
PostPosted: March 2nd, 2016, 2:51
Well, that was concise...
PostPosted: March 2nd, 2016, 2:58
Run a SMART check against the drive. Look for reallocated, pending or uncorrectable sectors.
http://crystalmark.info/software/Crysta ... dex-e.html
I hope that was more helpful.
PostPosted: March 2nd, 2016, 2:59
Thank YOU Mr. Akbar!! That was... And I'll post the results...
PostPosted: March 2nd, 2016, 10:03
God is great.
PostPosted: March 2nd, 2016, 20:13
Alohaa fzabkar!
Голод не тётка!
Users browsing this forum: Majestic-12 [Bot], Pi0tR and 60 guests
