Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Problem SSHD - PCB death - that is problem BIOS vs. NAND
PostPosted: February 6th, 2016, 18:20
Pepe, thank you for your answer
But you can write more specifically some details?
PostPosted: February 15th, 2016, 12:25
Nobody knows nothing ?
Interesting....:)
PostPosted: February 15th, 2016, 15:54
This is from ace lab forum:
1: reading the original disk ROM
2: Read spare ROM
3: Load Spare disk ROM
4: Replace CAP RAP SAP
5: Load LOD, this process fails, wait one minute, do not de-energized.
6: re-power, again loaded LOD.
7: Start copying data
http://forum.acelaboratory.com/viewtopi ... 154&t=8760
 Post subject: SSHD recovery
PostPosted: February 23rd, 2016, 20:48
This may work on some particular firmware, so there's a reason to try, but for most cases you won't have the drive initialized properly on step 6 after resetting the power. Things will look like you're working with the donor SSHD and that's a dead end.
That's not true. We work with SSHDs and can take up this drive.
If SSD part failure is the only problem with it, fee will be very reasonable.
PostPosted: February 24th, 2016, 6:10
The basic problem with these drives is the SSD part losts adaptives in patient ROM. Thats why the SSD part of these drives are dead, and stays BSY state the drive.
So the solution is use patient CAP-RAP-SAP contents in donor ROM using donor PCB.
I have resolved my case with this method and got 100% data back.
PostPosted: February 25th, 2016, 9:08
Frends,
It's done.
This method (6 step) is working, but with other donor.
I d't know - why my first donor (totaly identical) was not god for these method.
Thank to all for help.
PostPosted: February 29th, 2016, 2:18
Hello friends,
Is this the same problem Refer to attachment for the terminal Log
Disk not powering up
Finally gives following error
SIM Error 101F LBA 0000000000000000 FD 08423093
RW Error 00000000
Table Recovery Faked and Completed
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
TERMINAL.txt [9.24 KiB]
Downloaded 715 times
PostPosted: March 2nd, 2016, 9:54
igen,
can you contact with me via priv. mail? I'm from Poland too, and I have the same problem with my sshd.
patryk.cz1@gmail.com
Thanks.
PostPosted: March 3rd, 2016, 4:03
My disk is ST1000LM014 /DEMD
To try the 6 Step solution one needs the load the LOD but in my case SA is locked
we don't full access to SA The donor drive is not able to create the loader or copy DT
So how does one handle this drive
Any suggestions
PostPosted: March 4th, 2016, 13:32
You don't need LOD.
1. read ROM from patient PCB with boot mode code
2. read ROM from donor drive
3. create a hybrid ROM using donor PCB rom (copy patient CAP-RAP-SAP content into donor ROM image)
4. write the new hybrid ROM to DONOR PCB using boot mode code
5. start up patient with donor PCB (first or second, or third time the drive will not initilazie fine, be patient! Try some diagnostic test in terminal mode)
6. after the drive initialize itself and have sector access, start imaging drive
PostPosted: March 5th, 2016, 4:44
Can I replace rom integrated circuit from patient to donor? Or maybe can I replace whole pcb?
Patient and donor are same:
PN: 1EJ164-071
FW: LVD3
PostPosted: March 27th, 2017, 5:53
igen or saltwater, can anyone do this job for me? None of the local data recovery places could do it (I tried two). I want the data back for photos and uni files. I do not have equipment and experience to do this myself. You would get may gratitude and help (if I can help with anything, will show you around Sydney if anyone vist) plus reasonable costs for the repair.
My drive is:
ST1000LM014
1EJ164-305
FW SM25
can be emailed at robert.pawel.lipka gmail com
Can communicate in English or Polish, but sorry, not Hungarian :)
PostPosted: March 27th, 2017, 17:51
If you can find a technician to read and program your ROM, I can edit it for you as per saltwater's instructions:
You don't need LOD.
Users browsing this forum: No registered users and 231 guests
