 Post subject: Laptop Hard Disk data recovery
PostPosted: March 3rd, 2016, 3:20
My laptop hard disk is gone :( please help me to recover the data. :cry:
 Post subject: Laptop Hard Drive data recovery
PostPosted: March 3rd, 2016, 4:05
Do not use HDD Regenerator. Chances are very high that it will make the situation worse by torturing the drive to death.
You didn't provide any symptoms, but if the drive is still accessible and you want to go DIY way, use an utility like GNU ddrescue to make an image of it. Then recover the data by scanning that image.
 Post subject: Re: Laptop Hard Disk data recovery
PostPosted: March 3rd, 2016, 4:32
-i was working on my laptop and suddenly by open an heavy excel sheet it hanged..
-retarted a couple of times but didnt work and took out the hard disk and connected to a 2.5 external case......as soon as i connect to external case i should a couple of kreech krech kind of noise and sounds as the reader arm is moving back and forth. then the sound calms down and laptop detects the hard disk and shows in disk management. but there is no partition ...even other softwares i tried to scan with...they say MBR is damaged or bad sectors.
PostPosted: March 3rd, 2016, 4:33
Dmitri buddy i am so in a big mess....please help
PostPosted: March 3rd, 2016, 7:26
You have 2 heads inside, one of them or both are gone and/or media damage.
Sorry to say, but this is not a DIY case.
PostPosted: March 3rd, 2016, 8:57
If it's clicking like that there's nothing that any software or DIY can do to help. Get it to a professional data recovery company with proper equipment to work on it. Every time you're powering it on it's making it worse.
PostPosted: March 3rd, 2016, 9:28
+1
drive with physical problem no DIY.
if data is important send to someone who has proper tools and knowledge.
Data Recovery Pakistan
PostPosted: March 10th, 2016, 2:38
Is the hard drive clicking? Can you hear any sort of noise from it?
Maybe you can try this out - https://youtu.be/wdhkuzk_x4c
Users browsing this forum: No registered users and 83 guests
