Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: WD20NMVW-11AV3201
PostPosted: March 7th, 2016, 9:31
The customer bring me the drive above with "Slow responding + dead head 2,5"
The partition open in recovery software but with bunch of bad sectors because of H 2 and 5.
After replacing heads with matched donor, heads 2 and 5 back intact now. But when I tried to open the partition it shows nothing and I am trying to scan the entire drive now.
Very weird, why after replacing heads the partition become inaccessible?
Any thoughts?
Thanks in advance.
 Post subject: Re: WD20NMVW-11AV3201
PostPosted: March 7th, 2016, 12:14
Possible other heads are now NOT compatible or something trivial is being overlooked.
PostPosted: March 7th, 2016, 12:38
You mean donor heads are not compatible?
But the drive is working now, even head 2 and 5 are intact. Surface test is almost fine too.
Any suggestions?
PostPosted: March 7th, 2016, 13:40
what tool you use to rectify slow problem ?
can you show us sector 0, 63 & 2048 ?
what i have understand that after swapping heads you are trying to access data through windows ?
Data Recovery Pakistan
PostPosted: March 7th, 2016, 16:00
I am not in the office now. So, I can't upload sector 0,63 and 2048.
I already imaged the patient to a functional drive.
PostPosted: March 7th, 2016, 19:50
Any suggestions?
Yes, meant in the previous post heads other than #2 and #5 from the donor head assembly.
Not sure what "drive is working now" mean. Could mean many things.
If surface test on all heads is fine, then all seems fine.
So, something else is going on.
PostPosted: March 8th, 2016, 5:38
If I understand you correct, you have a full sector-sector clone of the drive.
If so, it could be just a lost partiotion, scan with R-Studio and see.
If not, the drive maby has encryption on it...either as a Wd external or by client SW.
http://www.rescue-it.se
PostPosted: March 8th, 2016, 6:00
could it be translators also ?
PostPosted: March 8th, 2016, 11:24
First, thanks for replies.
It's not a translator issue I believe.
After scanning the entire drive with r-studio shows the folders with correct names empty and a lot of extra found files with correct name and capacity but not working.
I think data has been shifted.
Any suggestions please?
PostPosted: March 8th, 2016, 11:35
Here is sectors 0,63 and 2048 :
Sectors.rar [1.14 KiB]
Downloaded 590 times
PostPosted: March 8th, 2016, 11:44
data is definitely shifted
each sector you have uploaded (0, 63 & 2048) has 516B instead of 512B
you have extra 4 bytes @ the beginning (0x04 0x02 0x00 0x00)
(how can it be ?)
PostPosted: March 8th, 2016, 11:52
Thanks for the quick answer sir,
Actually I don't know how this happened.
Is there any advices , please?
PostPosted: March 8th, 2016, 13:35
Any thoughts?
Thanks in advance.
how you apply the slow fix ? did you manually patch MOD 02 ??
i would check by writing back the original MOD 02 without slow-fix.
PostPosted: March 8th, 2016, 13:46
I applied slow fix from MRT.
PostPosted: March 8th, 2016, 14:22
did you backup MOD 02 ?
if yes, write it back and see if you get correct geometry of the drive e.g 512b per sectors.
PostPosted: March 8th, 2016, 16:33
I'm presuming you're using MRT to clone?
If so, post those same sectors read directly in the WD utility and not from the cloned copy.
Have heard things about the MRT "data extractor type tool" causing issues.
PostPosted: March 8th, 2016, 18:08
Thanks for replies friends.
Special thanks to Mr. Jermy he was trying to help me at this issue from 3:00 PM to 10:30 PM :)
@ Mr. Sean: I will post those sectors again from WD utility tomorrow when I get to the office.
Thank you very much.
PostPosted: March 9th, 2016, 6:20
Sectors directly from WD MARVEL utility MRT :
Sectors from MRT.rar [1.19 KiB]
Downloaded 618 times
PostPosted: March 9th, 2016, 7:09
sector 0, MBR is missing the signature.
sector 2048: NTFS boot sector appears to be normal corresponds to a partition size:
0xE8DF7FFF = 3906961407 Sectors = 1863GB, correct 512b per sector, type NTFS.
as Sean said it could be another MRT bug.
BTW, if you connect original drive does it show the partition ?
PostPosted: March 9th, 2016, 8:42
Thank you all my friends. Case closed as the customer not willing to pay additional fees for DR.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 300 guests
