 Post subject: ST31000340AS head stack replacement
PostPosted: March 12th, 2016, 1:47
I have the following Seagate Barracuda 7200.11 1TB drive:
    Model: ST31000340AS
    P/N: 9BX158-302
    Firmware: SD04
It spins up, clicks 11 times, and then spins down. It is not recognized in the BIOS.
I tried a new identical PCB (with BIOS swap) but the problem didn't change. My next step is to try a head stack replacement using a donor drive. I have a clean air enclosure and a head replacement tool for this model. Now I need a donor drive but I haven't found a very close match on eBay. There's plenty matching the model number but finding matching P/N, Firmware, etc. seems quite rare. Which of these drive properties are actually required to match exactly (or closely) in order to donate a head stack?
    S/N
    Model
    P/N
    Firmware
    Date Code
    Site Code
    Product of [Country]
    PCB Sticker
    PCB Silkscreen
 Post subject: Re: ST31000340AS head stack replacement
PostPosted: March 12th, 2016, 4:40
Is this a client's drive?
PostPosted: March 12th, 2016, 4:42
No, this is my drive.
PostPosted: March 12th, 2016, 4:56
Do you have experience on head swaps?
Or are you willing to throw away several hundreds $$$ and after send it to a lab?
ACELab partner
PostPosted: March 12th, 2016, 5:01
No, this will be my first head swap. I'm willing to spend several hundred on attempting a repair but not $1000 on professional recovery.
PostPosted: March 12th, 2016, 5:44
No offense, but if this is your first head swap chances of success are very low, further these Seagate drives quickly damage the surface in case of head failure. have seen this model with media damage many times.
I highly suspect media damage on these models.
Data Recovery Pakistan
PostPosted: March 12th, 2016, 18:08
That's sad news. But I'm not dissuaded by this and am hoping someone can provide an answer.
PostPosted: March 12th, 2016, 18:20
if "MindMergepk's" comment:
is not what you wanna hear
then I am willing to volunteer and provide you what you wanna hear, but I need to tell you it's not gonna be the truth, the truth has been told you by "MindMergepk" already
PostPosted: March 12th, 2016, 18:51
I understand. Yes please.
PostPosted: March 14th, 2016, 2:11
Hello Repair123 ,
For Head Swap Seagate , you need to match patient's model no , First 3 letter of Serial no & site code .
let us know the result. if you have clean chamber make sure that hepa filter should be 0.3 mn
good luck.
Peter
PostPosted: March 14th, 2016, 2:37
or you meant filtering 99.97% of airborne particles 0.3 µm ?!
PostPosted: March 14th, 2016, 11:20
Thank you very much alexpeter. I'll let you know how it turns out once I receive the donor in a few weeks.
PostPosted: March 14th, 2016, 15:47
alexpeter wrote:
Hello Repair123 ,
good luck.
Peter
The first letter of the s/n is already the Site Code. And it is not important.
PostPosted: March 15th, 2016, 16:40
Professional recovery could be cheaper than you think. But only if you didn't try yet.
PostPosted: March 16th, 2016, 5:13
The problem is even if the head swap is successful you will run into read errors, firmware problems etc.
Do you have the tools that can handle this after the head swap?
Web: https://www.day1data.de
PostPosted: March 16th, 2016, 13:30
No I don't. As I understand it, the tools (such as PC-3000 and DFL) are prohibitively expensive for an end user so if these issues do arise then I will consider the data lost.
PostPosted: March 16th, 2016, 13:50
Sorry to say that, especially with this model, that it's a 99.999999% certainty that this WILL fail given the lack of experience and tools... :-(
PostPosted: May 3rd, 2016, 14:32
I received the donor drive and performed the head swap but it it didn't work. Although the head swap itself went well, it was probably pointless because when I opened the patient drive I noticed that the top platter had 2 circles of debris on it (one at the center and one near the outer edge). The filters were blackened. So, I consider the data probably lost forever but I'll keep the drive in case many years down the road professional data recovery becomes affordable. In the meantime, is there anything that I can do aside from bringing the drive to a professional or buying very expensive equipment? Compressed air on the debris?
PostPosted: May 4th, 2016, 4:05
again no offense.
Users browsing this forum: Google [Bot] and 137 guests
