 Post subject: Two ST2000DM001 BSY after imaging 100 MB
PostPosted: March 11th, 2016, 19:08
Hey guys,
a Buffalo Linkstation collapsed... inside two mirrored ST2000DM001. both imaging properly with MRT tool... Power Reset then imaging 100 MB (each 10 seconds) > BSY > Power Reset > Loop...
wondering if there is a fix to this BSY issue.. seems to be very common. Strange that the two drives seems to have the same issue.
Greetings
Benjamin
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
 Post subject: Re: Two ST2000DM001 BSY after imaging 100 MB
PostPosted: March 12th, 2016, 17:23
did you take care on 93 sys file ?
PostPosted: March 13th, 2016, 0:58
Buddy ,
The MRT Guys Only Sell " MRT " No Manual Till Date For The Tool .Its a Pity
PostPosted: March 16th, 2016, 6:42
Hey guys,
I optimized the settings so that every 8 seconds 100 MB have been read by MRT-Tool. After Power Reset there was a small time frame where each of the mirrored HDs were accessible.
The second imaging process I used PIO mode that was very stable. at approx. 500 kb/s in that case.
1. HD 40000 errors (see screenshot below) - seems to be the HD "blown" first
2. HD 4000 errors (see screenshot below)
The XFS Filesystem seems to be recognized by Reclaime.
Maybe with the Sysfile 93 it the imaging process would have been more stable and faster?
Thanks for your help. The case ist technical successful. Now it should be economically successful too.. the customer took the hd after diagnosis and said he will double-check it.. a friend of him will try it.
Thank you for your impulses and greetings from Germany,
Benjamin
File comment: RECLAIME: 1. HD with more errors - seems to be the HD with quit the RAID array first.
File comment: 10 times more errors than 2. HD
PostPosted: March 17th, 2016, 2:38
Spildit wrote:
Looks more or less good to me ...
Sysfile 93 would be the same as disabling reloaction, media cache, etc with cogen, same as explained here but saved on sys module - http://www.hddoracle.com/viewtopic.php?f=83&t=557
also : - http://www.hddoracle.com/viewtopic.php?f=83&t=557#p7383
Regarding cloning in PIO it does work great on those Seagates, despite the fact that it's ... sloww ....
Spildit ,
I too Think Its a JOB Done Fine .Wish Now He Gets The Money
PostPosted: March 17th, 2016, 4:26
+1 Always take care of Sysfile 93 before cloning on these drives.
Web: https://www.day1data.de
PostPosted: March 17th, 2016, 12:55
Yes ,
But MRT Guys Teach Them Nothing "Thats the core issue " .No new videos no new manuals etc etc
PostPosted: March 18th, 2016, 14:02
Yes ,
Thanks guys... I learn a lot here.
PostPosted: March 18th, 2016, 15:17
I wouldn't count on economic success if you routinely provide the recovered data for the customer or his friend to verify as okay. It might be a better idea to provide a listing of files (using snap2html) and thumbnails of pictures (I take a video of Picasa while it quickly scans all the picture thumbnails) and only release the data once the customer accepts that the recovery is a success--by paying before releasing the data.
PostPosted: March 18th, 2016, 16:28
Hey LarrySabo,
Gladly I gave the customer the HD of which I made an image. He wanted to have a diagnosis by a friend of him. Customer called me If the friend can open the drive to fix it. :shock: He wanted to make sure that I have the images save... I said to him do what you have to do... but I advised otherwise. But he has to hurry up. 4 TB of Image Space is much... Still in negotiations with customer.
The tool you recommended will help a lot.
Greetings
Benjamin
Users browsing this forum: No registered users and 111 guests
