 Post subject: Blown IDE Interface? - ST3360320ACE - DB35.3
PostPosted: March 18th, 2016, 14:12
Hello guys,
here I have a ST3360320ACE 360 GB with a blown IDE Interface?
P/N: 9BK03J-061
FW: 3.ACD
Date Code: 08277
I need help to find a suitable donor board. Any recommendations?
Even If I have a board is it possible to access the data without transferring informations? Or is there a ROM-Chip which sould be transferred?
Greetings from Germany
Benjamin
EDITED PS: The Pic with the losen screw I added... ... and the drive has two missing IDE Pins too..
1. markings on the main chip 2. worn out losen screw 3. 2 missing IDE Pins 4. small blown technical component... What has happened to the drive... wondering If I use a new board... Maybe there must be a mechanical issue too...
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
 Post subject: Re: Blown IDE Interface? - ST3360320ACE - DB35.3
PostPosted: March 19th, 2016, 9:00
I googled for over an hour now... this board seems to by fckin rare... even If I find the board - what do you think is it worth the effort or should I sent the drive to someone that is able to fix the issue.
customer is willing to pay 800 - 1000 €
PostPosted: March 19th, 2016, 9:05
Find a matched PCB and transfer ROM.
Is the drive spin up with normal calibration or up normal noises?
PostPosted: March 19th, 2016, 9:31
Hi, whats the Pcb number? Look at the white sticker on circuitboard...starts with 100xxxxxx, is it 265364?
http://www.rescue-it.se
PostPosted: March 19th, 2016, 9:41
if you are not comfortable, better send it someone.
BTW, it is not F3 Arch drive.
Data Recovery Pakistan
Users browsing this forum: No registered users and 121 guests
