 Post subject: Hikvision FS and file format
PostPosted: March 22nd, 2016, 20:15
Does anyone know what FS and what file format is been used in hikvision DVR ?
TIA
 Post subject: Re: Hikvision FS and file format
PostPosted: March 23rd, 2016, 1:42
Can you post a binary file dump of the first 1,000 hdd sectors ?
(Wh, DD, whathever tool suits you)
PostPosted: March 23rd, 2016, 3:16
there is a format converter on this page that may lead to some answers:
http://overseas.hikvision.com/en/tools_82.html
possibly look through this software for copyright stuff or nuggets that say what format. looks like at least some of it uses fat32
also checkout:
http://www.cctvforum.com/viewtopic.php?f=1&t=40573
and
https://books.google.com.au/books?id=xp-oCgAAQBAJ&pg=PA188&lpg=PA188&dq=file+format+hikvision+DVR&source=bl&ots=xf5zYm3YBN&sig=7YAkl5FTc7M0rro9vIUF0a1Hbzo&hl=en&sa=X&ved=0ahUKEwid9YyyoNbLAhXCmJQKHcPCBlEQ6AEITzAJ#v=onepage&q=file%20format%20hikvision%20DVR&f=false
PostPosted: March 23rd, 2016, 4:47
TIA
it should be WFS.
can you post the sector 0 here ?
Data Recovery Pakistan
PostPosted: March 23rd, 2016, 5:15
Thanks guys
@-BR- there is nothing in the first 1K sectors except for sector 1 and 2, everything else is filled with 0x00
regarding sector 1 and 2, will post it later.
@ HaQue, I know about the format converter, but I don't know what's the initial file type format.
@MindMergepk, nothing to post, sector 0 is filled with 0x00
PostPosted: March 23rd, 2016, 7:19
what is in sector 1 & 2, can you post ?
PostPosted: March 23rd, 2016, 8:08
sector 1 + 2 attached
sec 1-2.zip [389 Bytes]
Downloaded 686 times
PostPosted: March 23rd, 2016, 8:33
maybe you can buy just the chapter from the collection of papers, should have everything you need:
PostPosted: March 23rd, 2016, 10:07
Sent you PM
-BR-
PostPosted: March 24th, 2016, 11:06
You didn't mention the DVR model, but if necessary, we should be able to help recovering the data from it remotely.
Please feel free to contact me.
PostPosted: March 31st, 2016, 3:35
Hikvision uses hikfat filesystem which is supported by DVRexaminer
http://info.dmeforensics.com/blog/dvr-e ... -released/
http://dvrexaminer.com/
PostPosted: March 31st, 2016, 4:28
WOW, doing it manually will be cheaper.
Thanks for the info though.
PostPosted: March 31st, 2016, 5:10
holy cow
Users browsing this forum: No registered users and 208 guests
