 Post subject: samsung motor does not spin after head replacement.
PostPosted: April 7th, 2016, 2:22
I understand that samsung HDD required to replacement identical head from donor drive that has
Forth character in the alphabetic code printed on the label at the rear side od the drive should match.
I had changed a head with different character due to unable to find the exact donor drive.
My head drive's Fourth letter is "A" ( If anyone has it, please pm me.)
Does anyone has success by modifying anything to let other character read as well?
 Post subject: Re: samsung motor does not spin after head replacement.
PostPosted: April 7th, 2016, 2:56
fourth char. ?
https://www.donordrives.com/blog/matching-guide#samsung
rear side ?
You missing some details, model for example Etc.
PostPosted: April 7th, 2016, 3:27
heads are not compatible.
read here:
https://forum.hddguru.com/viewtopic.php?f=1&t=33216
Data Recovery Pakistan
PostPosted: April 7th, 2016, 4:13
Pre amp is incompatible if a Samsung doesn't spin up after a head swap.
Can you start by telling us the model of the drive or a photo so we can help you more.
Web: https://www.day1data.de
PostPosted: April 7th, 2016, 7:13
Hi guys,
Client drive
Model: ST1000LM024
HDD P/N : HN-M101MBB/AVA
FW : 2BA30004
REAR : M8BP2
REAR : NLGAT71Q9
DONOR
Model: ST1000LM024
HDD P/N : HN-M101MBB/LCP
FW : 2AR10001
REAR : M8E
REAR : D41C7035BN
PostPosted: April 7th, 2016, 10:08
Now I understand what do you mean by rear, although I never bothered with this label, but now I don't understand why would you need an "A" on the fourth char (you don't have it on the original (patient) drive)
BTW, can you post the terminal log ?
PostPosted: April 7th, 2016, 10:20
http://hddguru.com/articles/2006.02.17- ... k-Q-and-A/
According to the above link says required 4th char.
PostPosted: April 7th, 2016, 10:21
How do I view the terminal log?
PostPosted: April 7th, 2016, 10:43
terryhoho wrote:
http://hddguru.com/articles/2006.02.17-Changing-headstack-Q-and-A/
I can't find it and definitely not gonna read the entire article now, but my guess is, you mixing things up.
I'm almost positive that the fourth char. you have read about is for WD HDD's HSA replacement (fourth DCM char.)
you'll need a TTL cable for that (like this for example)
How to connect a terminal cable on a Samsung drive ?
http://www.hddoracle.com/viewtopic.php? ... =189&p=432
PostPosted: April 7th, 2016, 18:44
No, the article definitely refers to Samsung.
However, the article was published in 2006, so things may have changed a lot since then.
As for WD ...
In the alphabetic DCM code the sixth (and quite desirably the fifth) characters must be identical
Users browsing this forum: Majestic-12 [Bot] and 37 guests
cron
