 Post subject: WD10EZEX
PostPosted: September 2nd, 2013, 5:01
WD10EZEX-00ZF5A0/DCM EANNHT2CHB /DCX 4Z04F0356 1TB HDD HAVING ISSUE GETTING IN DRD DSC STATE BUT NOT SHOWING DETAILS IN WD UTILITY MDL/SN/FW (aLL NOT GETTING DETECTED)/CAPACITY SHOWS MB ()
WHEN I POWER ON HDD INITIALLY MAKING SLIGHT HEAD STUCKING NOISE AND SPIN DOWN
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 45.AAF
ROM generation.......................... : 45.AAF
Link table version...................... : E8.02.
Consolidated ROM version................ : 004500AA
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 124 525
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 004500AA
Code type to check...................... : TypeN
Code addr............................... : FFE00000
Code size............................... : 327681
Code reading............................ : RAM Range FFE00000 (050001) reading error Device Error Detected: "VSCE KEY SECTOR MUST PRECEED DATA XFER REQUEST"
No HDD RAM access, LDR upload is recomended
IF TRYING TO LOAD LDR MANUALLY GIVES ERROR
RAM RANGE....VSCE KEY SECTOR MUST PRECEED
ANY SUGGETIONS ,
THANKS IN AdVANCE
 Post subject: Re: WD10EZEX
PostPosted: September 2nd, 2013, 5:41
Probably the drive has bad heads, that's why it spins down.
Also, you can't edit map in RAM because probably pc3k does not have the right ram address for that family.
PostPosted: April 9th, 2016, 23:36
I know this tread is really old, but I haven't been able to find a solution to this here or on ACE's forum. I have the same drive with practically the same issue.
- Drive POWERS ON
- Makes a slight stucking sound, THEN Powers off
- But in PC-3000 it is DRD DSC
ITechno mode key
RAM:
Heads number............................ : 8
ROM:
Read ROM................................ : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 318 137
SA defects assigned..................... : 3
ROM Modules:
ROM version............................. : 21.2CH
ROM F/W version......................... : 0021002C
Overlay F/W version..................... : 21.2CH
Servo F/W version....................... : N0.38
Heads number in use..................... : 8
Heads map............................... : 0,1,2,3,4,5,6,7
Code size............................... : 327680
Code reading............................ : RAM Range FFE00000 (050000) reading error Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
Code type to check...................... : Type1
Code addr............................... : 1081A800
Code reading............................ : RAM Range 1081A800 (050000) reading error; unexpected error: -; unexpected error: Operation aborted
Module (0001) read error Module ID 01 reading error Data request error - Device Error Detected: "DISK SERVO SPINDLE SPINUP ERROR"
I would really appreciate any help I can get.
Thank you.
(P.S- Site admin banned two other accounts that I had created and Im really unsure why??? Tried to find a way to contact them, but was unsuccessful. If my account is going to be banned again, can I please know what im doing wrong?)
PostPosted: April 11th, 2016, 3:09
Your drive might have heads or FW issues.
Have you tried to disable SA regions and load a loader?
PostPosted: April 12th, 2016, 0:24
Thank you for the help.
Yes, I tried to upload LDR and I got this message:
I think it may be bad heads also, but I wanted to be 100% sure before.
Thanks again.
PostPosted: April 12th, 2016, 0:29
In my case head bad
PostPosted: April 12th, 2016, 0:51
Im going to look for a donor. Ill update this post once I find the solution.
Thank you.
PostPosted: April 13th, 2016, 21:10
UPDATE: In my case it was the heads. Replaced it with a good donor and its reading good. For some reason head 5 is not reading well at all. I'm assuming platter damage, but I'm going to image everything else and come back to that later.
Thank you DRCP.
PostPosted: April 18th, 2022, 1:23
Thank you DRCP.
I am having the same issue. I changed the heads though. Still having the same problem
Users browsing this forum: No registered users and 83 guests
