 Post subject: WD10EARX-00TDHB0 ROM+LDR
PostPosted: April 6th, 2016, 14:42
Please share any ROM version for the below model;
WD10EARX-00TDHB0
thanks in advance.
Data Recovery Pakistan
 Post subject: Re: WD10EARX-00TDHB0 ROM+LDR
PostPosted: April 6th, 2016, 15:37
Any version ? Why is it ?
Can you upload a pic from the front label ?
PostPosted: April 8th, 2016, 13:59
any one has plz share
PostPosted: April 9th, 2016, 8:53
21-AUG-2011
WCAV5T624244
007700EE-
ٍSPT1974
MA
ROM.rar [177.44 KiB]
Downloaded 901 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 9th, 2016, 14:25
thanks tawfeek.
what is the family of drive ? is it Sadle 2D ?
thanks anyway.
PostPosted: April 9th, 2016, 14:48
You collecting any version exist ? or need it for DR ?
PostPosted: April 10th, 2016, 4:23
need it for DR.
Native ROM is missing.
PCB is 2060-771898-002 Rev A
PostPosted: April 10th, 2016, 9:49
Yes , Sadle 2D
i forget the LDR here is it 011 and 01
011.01.rar [369.26 KiB]
Downloaded 886 times
Tawfeek Mokhtar
PostPosted: April 11th, 2016, 8:06
thanks Tawfeek
PostPosted: April 11th, 2016, 11:17
You welcome & good luck
Tawfeek Mokhtar
PostPosted: April 12th, 2016, 6:26
You sure it's EARX and not EADX? I've never seen EARX-TDH.
Also TDH is Dragfly 2, not Sadle 2D.
Am I missing something?
PostPosted: April 12th, 2016, 13:40
@Northwind, It is EARX, i have double checked it.
thanks for the info about family.
@Tawfeek, are you sure that it is correct rom, it doesn't have ROYL sections in it, what tools you use to read this ROM ?
PostPosted: April 12th, 2016, 14:12
I got it from afriend who have pc3k too . pm me if you want the full resources with tracks too . i'm sure it's pc3k from tracks .map
Tawfeek Mokhtar
PostPosted: April 12th, 2016, 14:34
can you plz share the complete modules so we can build it and compare with the one you attached.
PostPosted: April 13th, 2016, 6:07
It's not that I don't believe you, but for archive reasons, can you upload a pic from front label? I have never seen this model and I need to classify it.
PostPosted: April 13th, 2016, 7:21
Tawfeek wrote:
21-AUG-2011
WCAV5T624244
007700EE-
ٍSPT1974
MA
WDC WD10EADX-00TDHB0
00000000  52 4F 59 4C 04 00 1E 00 0D 00 01 00 4F 5F F9 7F  ROYL........O_ù.
00000010  30 30 30 31 30 30 30 30 00 00 00 00 00 00 00 01  00010000........
00000020  37 37 2E 30 34 44 37 37 00 01 00 00 00 00 50 01  77.04D77......P.
00000030  4E 62 B0 5F 9A 22 00 01 FE 7F 00 00 00 00 20 00  Nb°_š"..þ..... .
00000040  01 01 00 01 00 00 57 44 43 20 57 44 31 30 45 41  ......WDC WD10EA
00000050  44 58 2D 30 30 54 44 48 42 30 20 20 20 20 20 20  DX-00TDHB0
PostPosted: April 13th, 2016, 8:06
I didn't notice that , As i said it's not from my DB . it's from A friend profile . i just focused about 00TDHB0
i'm so sorry
Tawfeek Mokhtar
PostPosted: April 14th, 2016, 3:29
here is the front label:
PostPosted: April 14th, 2016, 5:31
MindMergepk wrote:
need it for DR.
Should that be 771698?
I notice that the R/N number on the label is 701590. Doesn't this normally reflect the PCB P/N? Could the PCB also be foreign? I would check the IC date codes against the manufacture date on the label.
This drive is fake.
