 Post subject: my passport essential
PostPosted: April 29th, 2016, 3:52
can someone identify what is this
 Post subject: Re: my passport essential
PostPosted: April 29th, 2016, 3:59
Encryption...
http://www.rescue-it.se
PostPosted: April 29th, 2016, 4:09
is possible to identify type of encryption
PostPosted: April 29th, 2016, 4:23
It's hard to find any WD docs that explicitly state the encryption algorithm, but I believe it is 256-bit AES.
FWIW, here is a My Book doc:
http://store.wdc.com/store/wdus/en_US/D ... y.13434000
PostPosted: April 29th, 2016, 12:52
thank you Mr_spokk and Mr. Žabkar.
How important is PCB revision
symwave sw6316-3vb14 d12823 00 and sw6316-3vb14 d1499 00
PostPosted: April 29th, 2016, 13:41
This should be enough: sw6316
PostPosted: April 29th, 2016, 15:38
reallymine: Western Digital MyBook/MyPassport decryption:
https://github.com/andlabs/reallymine
reallymine is a program that decrypts the encrypted hard drives of Western Digital MyBook and MyPassport external hard drives (and some rebranded derivatives).
Currently, it can only decrypt JMicron and Initio bridge chip-based devices that use AES-256-ECB encryption. I'd love to expand this to cover Symwave and PLX/Oxford Semiconductor bridge chips and the other known encryption modes, but I need your help; see below. It also does not currently handle entering passwords; if your drive is password-protected (and the bridge chip requires a password) but most of the work is already there (in kek.go); I just need to write the code that actually lets you type in a password, and then we'll be fine.
Simply run the program, providing the drive to decrypt and a file that the decrypted image will be stored to:
    reallymine encrypted decrypted
It appears that the program now successfully decrypts symwave bridges:
https://github.com/andlabs/reallymine/c ... 9dd86947d8
Merged the Symwave decrypter into the main program since it now seems to work fine.
PostPosted: April 29th, 2016, 16:44
Thank you Mr_spokk and Mr. Zabkar,
I Will try it, when I come back
PostPosted: April 29th, 2016, 18:53
Doesn't encryption usually have very high entropy? Are you saying this dump is part of the key, salt or some other part of the encryption itself? I don't see how this can be encrypted data.
PostPosted: April 29th, 2016, 20:18
The dump is sector 0. The repeating pattern of 16 bytes (= 128 bits) is consistent with encrypted zeros.
PostPosted: April 30th, 2016, 4:57
Thanks Franc, as you can see I know nothing about encrypted conventional drives :)
Users browsing this forum: Google [Bot], Majestic-12 [Bot], vmsameer and 180 guests
