 Post subject: Need help wd hdd 500Gb not detect
PostPosted: May 5th, 2016, 16:21
Banned User
Hello all friends
I use HDD WD 500Gb SN wx71ab01274 not detect error 0Gb. I need data recovery look forward help me use MRTPRO to recover data for this HDD
thank you
Banned for spamming
 Post subject: Re: Need help wd hdd 500Gb not detect
PostPosted: May 5th, 2016, 16:43
Will need more details than that. For example, is it making any noises? Is is spinning? Can you access SA?
Are you looking for remote support, or just need advice?
PostPosted: May 5th, 2016, 20:38
Banned User
HDD normal operation without noise, motor rotation will need you to help me advice
thank you
Banned for spamming
PostPosted: May 5th, 2016, 22:38
You didn't answer
data-medics wrote:
Can you access SA?
PostPosted: May 7th, 2016, 3:46
Banned User
jermy wrote:
You didn't answer
data-medics wrote:
Can you access SA?
I Cant access SA
can you help me
thank you
Banned for spamming
PostPosted: May 7th, 2016, 4:54
give me pic of hard disk . /front and back . and which tool u use
PostPosted: May 7th, 2016, 14:20
datahdd116 wrote:
I Cant access SA
Try a LDR
PostPosted: May 8th, 2016, 13:48
Banned User
Spildit wrote:
Do you have a BACKUP of the drive firmware or another drive to use as donnor or donnor FW ?
Try to load overlays from backup and then load DIR in RAM and save DIR TO RAM and try to access modules.
thank you I did succeed caused by PCB with head short circuit fault
Banned for spamming
PostPosted: May 8th, 2016, 14:13
Banned User
Spildit wrote:
What ?!
Bad/Shorted Pre-Amp ?
ok i sanitary point of contact on the PCB with the head leg and head reattach success 465Gb
very lucky
Banned for spamming
PostPosted: May 9th, 2016, 20:50
datahdd116 wrote:
Spildit wrote:
What ?!
very lucky
that mean you solve prb ?
if yes so back up all Firmware
keep in safe
http://www.hpwlab.com
PostPosted: May 10th, 2016, 16:20
Banned User
hpw333 wrote:
datahdd116 wrote:
Spildit wrote:
What ?!
very lucky
keep in safe
ok thank you
Banned for spamming
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 78 guests
