 Post subject: Trying to repair a Western Digital 2,5'' hard disk
PostPosted: May 9th, 2016, 2:55
Hello, some time ago my external hard disk fell from my desk and it stopped to work and to be recognized by computer.
I bought tools for heads replacement and i bought some faulty hard disks (the same model of mine) to make some tries about heads replacement.
So i removed the heads arm of my hard disk and i made 3 replacement with 3 heads arm removed by faulty hard disks, but nothing changed (i discovered that since the model is the same i also had to change the logic board according to its heads arm).
Maybe it doesn't work because i tried with 3 faulty hdds but anyway i'm suspecting that the problem is a platters misalignment.
How can i see that? Do you know any way to figure out if the the platters are misalignment?
The hard disk model is WD5000BEVT.
Thank you in advance
 Post subject: Re: Trying to repair a Western Digital 2,5'' hard disk
PostPosted: May 9th, 2016, 4:15
My advice would be, stop playing around - if the data is valuable to you - and send it to a DR pro, I hope you didn't turn it from bad to worse already.
Regarding your question, something like this can check it.
PostPosted: May 10th, 2016, 11:11
Thank you so much for your reply.
Can you tell me what could i do to turn it from bad to worse? I'm trying my best not to touch platters, i'm just removing heads arm and logic card.
About my question, do you know any way without tools (like that you linked) to have evidence of platters misalignment?
PostPosted: May 11th, 2016, 1:21
Hi
I agree with Jermy.
The problem is not misalignment.
The problem is you don't know how to do things the right way. One mistake - data gone.
PostPosted: May 11th, 2016, 8:36
northwind wrote:
Hi
I agree with Jermy.
Do you mean the fact that i'm not in a clean room?
PostPosted: May 11th, 2016, 10:10
Per il fatto che non stai lavorando in camera bianca oltre a non avere le attrezzature e la tecnica necessaria per poter effettuare un lavoro del genere.
Sostituire le testine è molto più difficile di quello che si crede, sul forum puoi trovare testimonianze di tecnici DR che raccontano di aver imparato a fare il cambio testine dopo decine e decine di tentativi (anzi alcuni dicono dopo centinaia)...
Come puoi pensare di poterci riuscire tu da solo senza qualcuno che ti insegni, senza attrezzature e con solo qualche tentativo alle spalle?
Spero per te che non sia troppo tardi, affida il tuo hdd ad un professionista ed incrocia le dita che i piatti non siano rimasti danneggiati dalle testine o da altro (esempio impronte, capelli, saliva ecc).
In bocca al lupo!
My firmware database:
PostPosted: May 11th, 2016, 17:49
How could heads, imprints of fingers, hair or spit damage platters?
In bocca al lupo!
Ciao Michael, grazie per la tua risposta.
Sto cercando di riparare l'hdd autonomamente solo per hobby, ormai per i dati mi sono rassegnato. Però vorrei capirne di più, perché tutto ciò è molto appassionante.
Prima di tutto... che cos'è un tecnico DR?
Per la precisione, un piatto come può essere danneggiato dalle testine, da un'impronta, da un capello o dalla saliva?
Grazie.
PostPosted: May 11th, 2016, 18:13
Please provide photos of all hard drive labels and what was wrong with faulty hdds and original hdd.
PostPosted: May 12th, 2016, 3:44
DR= Disaster Recovery (il DR quindi è il tecnico che si occupa di recupero dati).
Le testine si muovono sopra i piatti, la distanza tra testina e superficie è di pochi micron (millesimi di millimetro) quindi basta aver sbagliato qualcosa nel loro montaggio o non aver utilizzato strumenti appropriati che queste strisciano sulla superficie (anche per un solo istante) per creare danni irrimediabili (graffi).
Oltre alle testine ci possono anche essere fattori esterni quali polvere, impronte, fumo, capelli, ecc che sono di dimensioni maggiori della distanza che c'è tra testina e superficie, quindi puoi capire che una testina che si muove a grande velocità si possa danneggiare se urta qualcuno di questi elementi o peggio, gli agenti contaminanti potrebbero incastrarsi tra testina e superficie e graffiare tutta la superficie in un attimo.
Per farti un'idea più chiara...
http://www.riparafiles.it/index.php/Tec ... -disk.html
PostPosted: May 16th, 2016, 19:59
Why do you suspect the platers are out of alignment?
PostPosted: May 19th, 2016, 13:27
I do not know what was wrong with faulty hdds because i bought it on eBay as items to be tested.
At the moment i do not have these hdds with me. Why do you need labels?
Accidenti! Mi hai davvero dato un'idea della "grandezza" delle cose :D
Ad ogni modo ovviamente la mia speranza è riuscire a leggere almeno una volta l'hdd per poter recuperare i dati (anche parzialmente). Poi posso anche cestinare tutto.
Because i tried to install 3 different heads arm (with their related logic boards) with no success. This is the reason for which i asked if there is a method to figure out if the problem could be the misalignment of platters...
Users browsing this forum: No registered users and 223 guests
