 Post subject: Toshiba KAMOME USB 2.0 16GB RAW
PostPosted: May 9th, 2016, 13:57
Toshiba KAMOME USB 2.0 16GB become raw.
R-studio detect 16 GB, when I did scan,it will comes out nothing.
When use create image to disk will appear IO error (1117).
When use hd tune to do speed test, the test will stuck without proceeding more than 1 second.
Physical inspection doesn't point to any defect within eye level.
Any one please advice what tools is required to get into NAND drive recovery?
or any professional do re-seller job please PM.
- Only mechanical failures will be outsourced
- We need a turnaround of drive and data in 3 weeks
- Failed recoveries will not be charged
- Customer hardware is always returned
- You are located within ASIA
Of-course we believe that by offering this service to us you are an expert and knows what you are doing.
Business or private entrepreneur are both welcome as long as you know what you are doing.
PM fixed price per drive.
 Post subject: Re: Toshiba KAMOME USB 2.0 16GB RAW
PostPosted: May 9th, 2016, 16:41
It's very hard for anyone to give a price sight unseen. Could be a simple bad solder joint, or it could be a monolith nightmare. You'll need to get it physically to a lab that does flash recovery so they can actually evaluate it and see. The price range on this can be anywhere from a $50 solder fix, to a $2000 under the microscope nightmare.
I highly doubt any respectable professional will give you a fixed quote like you're asking. It's like asking for a lawyer to quote you for handling a court case, but he's not allowed to know what type of case it even is.
PostPosted: May 9th, 2016, 17:56
data-medics wrote:
to a ... under the microscope nightmare.
You probably meant hours days and weeks of research and reverse engineering... pinout, XOR, and the list goes on
PostPosted: May 9th, 2016, 23:35
It's not monolith.
its TSOP.
PostPosted: May 10th, 2016, 1:14
Talk to Sunny:
username networkpc3000
Skype: sunnydreamspace
https://forum.hddguru.com/memberlist.php?mode=viewprofile&u=7319
http://www.alldataback.com
He's your guy in Asia.
I would offer, But I am in Austral-asia ;-)
Users browsing this forum: No registered users and 21 guests
