Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Seagate F3 ROM Rebuild
PostPosted: May 12th, 2016, 17:45
I have a ST1500DM003 where the client tried to remove the ROM with pliers. The ROM is physically damaged. I have an exact matching board (model/part/fw) but the drive gives servo errors. Is there anyone out there who can rebuild a ROM on an F3. If so please PM me.
ST1500DM003
Grenada
HP16
 Post subject: Re: Seagate F3 ROM Rebuild
PostPosted: May 12th, 2016, 21:34
upload picture for terminal output
and try to short contact and goto T-level
then i can help you
http://www.hpwlab.com
PostPosted: May 13th, 2016, 0:51
Upload a picture of the chip damage. Maybe i can help you.
Not to rebuild a F3 ROM but to get data out of the butchered chip.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: May 13th, 2016, 5:13
Too many unique adaptives in the ROM to recreate it.
Your better to try an repair the damaged ROM and read the contents in a ROM reader.
Post a pic of the damaged ROM.
Web: https://www.day1data.de
PostPosted: May 13th, 2016, 9:11
Actually, there are three ways:
1. Try to fix physical damage as much as it allow to read ROM content (if there only pins are damaged you can try to remove some part of IC enclosure to fit some small wires by soldering or by some similar way) by programming tool.
2. You can ask one forum member (Peter from Hungary) for help (not for free) to regen ROM.
3. You can wait untill some DR tools vendor (ACElab, SalvationData etc.) research/buy method how to regen ROM content and buy their tool.
PostPosted: May 13th, 2016, 9:16
then i can help you
Did you read the question carefully? ;)
PostPosted: May 13th, 2016, 11:56
then i can help you
it's my error , i post answer to wrong thread
PostPosted: May 13th, 2016, 12:22
Here is a picture of the ROM. Just had confirmation from the client that he wants to pursue this so I will see if we can read it today. Its a little more than just a leg that's been damaged. But you never know.
PostPosted: May 13th, 2016, 12:34
To me, it just looks like the outer shell is damaged and it likely okay.
PostPosted: May 13th, 2016, 13:18
You were quite right Luke. The ROM did read so the board was also dead. Not sure what the client did but looks like he shorted the board at the same time. Now getting preamp failure message.
Boot 0x40M
Spin Up
TCC-001F[0x00026F7C][0x000270B7][0x000270B7]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YW
PreampFaultStatus = 0000YWMMMMMM
PostPosted: May 13th, 2016, 14:13
Looking at the way the rom ic was damaged I would go over every unpopulated solder pad on the pcb just in case small sm components have been knocked off. Of course one would be looking for the tell tell signs ie. sharp edges on the pads. Or are you getting the preamp errors using the replacement board and programmed rom?
PostPosted: May 13th, 2016, 14:19
Just to clarify, this output is from the clients drive with donor board and original ROM uploaded via boot code.
PostPosted: May 13th, 2016, 14:53
The logical approach would be to determine what is wrong with the original PCB. The failure mode may then shine a light on the current problem.
PostPosted: May 13th, 2016, 15:11
The board has multiple issues such as a removed TVS and smooth chip failure.
PostPosted: May 13th, 2016, 15:20
If the 5V TVS diode has been removed, then most probably there was an overvoltage on this supply. The user then most likely powered the drive without protection, resulting in failure of the preamp and damage to the 5V side of the SMOOTH chip.
See the following examples (yes, I know yours is a Seagate).
Catastrophic failures in Western Digital PCBs:
http://www.hddoracle.com/viewtopic.php? ... 119&p=5033
PostPosted: May 13th, 2016, 15:22
Agreed. Thank you :D
PostPosted: May 13th, 2016, 15:57
If you read the ROM to file, take a look and see if the serial number matches up with the drive.
PostPosted: May 13th, 2016, 16:03
Yes it did match, did some checking at several points of the ROM and it doesn't seem like its corrupt or a ROM from another drive.
PostPosted: May 13th, 2016, 16:11
If the ROM were corrupt, ie bad checksum, then the drive wouldn't start.
PostPosted: May 13th, 2016, 17:12
That's correct. Looks like toasted preamp.
Users browsing this forum: Google [Bot] and 73 guests
