Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate F3 ROM Rebuild
PostPosted: May 13th, 2016, 18:03
Preamp is fine. It's something else.
PostPosted: May 13th, 2016, 18:08
We shall see, based on guesswork.
PostPosted: May 14th, 2016, 9:11
Hi
Read the rom by boot code mode, and write it by boot code mode again.
it will solve the problem
Boot 0x40M
Spin Up
TCC-001F[0x00026F7C][0x000270B7][0x000270B7]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YW
PreampFaultStatus = 0000YWMMMMMM
PostPosted: May 15th, 2016, 14:08
waqas_ali766 wrote:
Hi
Boot 0x40M
Spin Up
Sorry but this didn't work, we still get the same error message. Out of interest why would this make a difference? Is it do do with the checksum? or reading/writing part 1 of the ROM vs. part 2?
PostPosted: May 16th, 2016, 8:29
Have you checked contents inside the ROM by external programmer or reader ? as i see , the client tried to remove but he did not remove ROM . soldering looking nice as factory assembled . maybe he is expert in soldering like Fzabkar... but if he was expert like fzabkar then he was never damaged ROM :) ... whenever you fix it ,please let me know also .I am interested in this kind of research . have a good day
PostPosted: May 16th, 2016, 8:36
F3T ROM regeneration is a big problem...There should be something for juniors to learn In F3T . so i request expert Drs to explain and share with new ones ,if they found any solution .
Users browsing this forum: No registered users and 126 guests
