 Post subject: External Drive Data Recovery
PostPosted: May 16th, 2016, 23:18
Hope I'm in the right place, I joined the forum for this post as it seems like an active community for data recovery.
I'm working on a drive for a friend... Apparently his wife completely filled it to the point that it won't mount anymore. I've pulled the 2.5 inch drive from it's enclosure and attached it to a computer to work on it. I tried a simple dd from my Ubuntu box to copy data to a larger drive in hopes that it would mount once it wasn't full anymore but have been running into errors about
exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock
and haven't been able to find a work around for that.
I've tried to run fsck but this is all I get:
sudo fsck /dev/sdb2
fsck from util-linux 2.27.1
I'm a little stumped at this point. I'm wondering if the original drive really is bad, at the beginning of my dd I was getting about 30MB/second and towards the end I was down to 6MB.
Any tips?
 Post subject: Re: External Drive Data Recovery
PostPosted: May 17th, 2016, 0:52
Hopefully
1. There isnt unusual noise coming from the drive.
2. There is no problems with the read/write heads
Can be a simple FW issue called slow response
PostPosted: May 17th, 2016, 1:45
Can you post a SMART report?
Some external enclosures are configured with 4KB sectors. If you remove the drive from such an enclosure and attach it to a SATA port on your motherboard, you expose its native 512e sectoring and render the file system inaccessible.
Can you show us the contents of sector 0?
PostPosted: May 17th, 2016, 16:31
FYI, it looks like this is not the only forum where the questions is being asked.
https://www.reddit.com/r/datarecovery/c ... _recovery/
PostPosted: May 17th, 2016, 16:43
Spildit wrote:
What is the full model of the drive ?
The model of the original enclosure might also be important. Some have hardware based encryption.
Users browsing this forum: Majestic-12 [Bot] and 222 guests
