 Post subject: WD Green smart clear
PostPosted: May 19th, 2016, 8:26
hi!
I have WD Caviar Green and i want to clear SMART in it. I have USB TxRx terminal which i used on Seagate. Is there any chance i can use it to clear smart on WD with this?
Thanks in advance!
 Post subject: Re: WD Green smart clear
PostPosted: May 19th, 2016, 10:01
I would say it's not possible for you even it's only some not serious SMART problems. Drive use special protocol for terminal mode that not the same like Seagate. I doubt you can solve it without special tools/utilities. And better to work via SATA interface, some utilities like WDR could help you. Or ask some profi guys in Poland (they there are) to help you, it is not expensive or even can be done for free. Good luck.
PostPosted: May 19th, 2016, 10:48
Thanks!
PostPosted: May 19th, 2016, 11:25
Banned User
Therion667 wrote:
hi!
Thanks in advance!
Hello
with model wd terminal other seagate, you need to use pro tools WDC
you see this post
https://forum.hddguru.com/viewtopic.php?t=23933
Banned for spamming
PostPosted: May 19th, 2016, 13:08
why all this complex ??
this guys seem that he is beginner
and SMART in WD is not so big prb to Clear
even with free tools he can clear smart
with some knowledge
http://www.hpwlab.com
PostPosted: May 19th, 2016, 13:16
Therion667 wrote:
hi!
Thanks in advance!
NO NEED To Terminal HERE
if you have good knowledge to work with HDD
you can work with Free WDR 5.3
if you didn't have it , i have good modified version
you can use it
1- Back UP HDD Firmware
2- try to hit Clear smart Button ( check smart after that , if not cleared go to next step )
3- Merge G To P
4- Clear and Regen translator
and your Problem will be fix 100 % after this step
if you can't do that , i can remotely help you
and don't play with HDD before you backup firmware
PostPosted: May 19th, 2016, 13:39
Perhaps I'm missing something here, but what's the point of clearing S.M.A.R.T. on a WD drive? Only reason I can think of is to sell it on ebay to an unsuspecting buyer who you're ripping off.
PostPosted: May 19th, 2016, 13:49
Generally yes, but sometimes you need to have good SMART because some systems prevent loading from drive with bad SMART (yeah, you can switch off SMART check in BIOS). Hope it will be used for personal reasons, not for selling.
Users browsing this forum: Google [Bot] and 73 guests
