Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate St1000DM000
PostPosted: May 21st, 2016, 8:12
13 'beeps' and spins down... heads. Pretty straight forward if there's no media damage for a pro.
Data Recovery Cape Town
PostPosted: May 21st, 2016, 12:47
stefanocps wrote:
i have same problem with drive
st1000dm003 1Tb
no more recognizable from bios
no strange sound, motor spin regualrly
if connect via serial i receive the same failure
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame 0480 0000 0000 3240 0008 0000 0000 0000 0EB4 0000 0000 0000 0000
0000 0000 0000 BFFA 8ECB 8800 880D 47CE 012A 11CE EBEE B3F5 53BF 0000 007F 0000
0000 001D 0004 0000
what could i do?
thanks
Short Read Channel then Go to T-Level
this prb may be bad PCB or Bad Head
but if You success To enter T-level With RD Channel
This HDD Will Repair
if you didn't know read channel you can see here
http://www.hpwlab.com/hdd-en/thread-145-1-1.html
PostPosted: May 21st, 2016, 12:52
vijayan wrote:
Rst 0x10M
CommandProcessorTask
Finished SIM Init
Finished InitCmdProcessor
StartDrive
Finished StartDrive
RW: Disc Ctlr Initialization Completed.
StartDrive
Finished StartDrive
ExecuteSpinRequest
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>
FAIL Op=0100 Resp=0007
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
FAIL Op=0100 Resp=0007/
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>x
FAIL Op=0100 Resp=0003
Send Status: COMRESET seen
Rst 0x10M
Finished S
LED:000000CC FAddr:0000F2E5
Rst 0x10M
Finished SIM Init
StartDrive
Finished StartDrive
StartDrive
Finished StartDrive
ExecuteSpinRequest
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/
FAIL Op=0100 Resp=00072
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>
FAIL Op=0100 Resp=0003Z
Input_Command_Error
F3 2>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.135 msecs
F3 2>U
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 1 mins 12 secs
R/W Status 2 R/W Error 84150180
F3 2>
84150180 this Head problem
Error DiagError 00006008 is Spin UP Failed
in your Case this is head Prb
PostPosted: May 28th, 2016, 2:05
Banned User
kpeddie wrote:
Was imaging this drive slowly through a lot of bad sectors, only really worked in reverse and in PIO mode but was getting there. Drive stopped and started to make beeping noise from voice coil and wouldnt go to ready. Thought it was heads but have disconnected PCB from drive and PCB also wont go ready on its own or with just spindle isolated
Terminal with PCB attached
ExecuteSpinRequest
No HOST FIS-ReadyStatusFlags 2002B001
Rst 0x20M
Servo Processor Is Reset.
Terminal with PCB not attached
ExecuteSpinRequest
In this case 10% PCB
Error 90% as Bad head
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
PostPosted: September 9th, 2016, 12:44
so far, i've found this:
http://www.hddoracle.com/viewtopic.php? ... =149#p2436
gonna try it this weekend :wink: , anyone could confirm/give additional advice please?
thanks in advanced...
PostPosted: November 22nd, 2016, 13:41
I have similar problem with my disk Segate Barracuda ST2000DM001 PN: 9YN164-302. I have attached logs from PUTTY. After last line I can not do anything, it freezes. What can I do with that problem?
Any ideas?
dysk.txt [2.31 KiB]
Downloaded 753 times
PostPosted: November 22nd, 2016, 17:13
Hello again,
The disk behaves exactly as that one in a short movie
https://www.youtube.com/watch?v=xx6GNejwjn4
I have also ST2000DM001, PN: 9YN164-302.
Best regards,
lskarbek
PostPosted: December 7th, 2016, 14:23
Any ideas? Nothing comes to my mind.
PostPosted: December 7th, 2016, 15:06
When you get servo errors, its usually an internal physical problem.
Users browsing this forum: No registered users and 218 guests
