 Post subject: Sandisk CF 128GB
PostPosted: May 26th, 2016, 11:46
is it encrypted? i asked few friends about it and some of them said: some models are YES
anyone tried this model?
Chip: Sandisk 07544 064G
Chip ID: 45 3A 95 93
Controller: 20-82-00549
 Post subject: Re: Sandisk CF 128GB
PostPosted: May 26th, 2016, 13:13
No. This controller not crypt data. Usually it is rebranded SM controller.
PostPosted: May 26th, 2016, 13:43
Thnx Michal, am dumping it now,
might need your help later
Will let u know
:mrgreen:
PostPosted: May 26th, 2016, 14:07
Generally this is to be told with the card or the dump on hands, but chances are that proper translator-based reassembly won't be possible.
We mostly get these of 64 GB capacity, but worked with the larger ones as well.
What kind of data you're looking to recover? Photos should be pretty recoverable, but videos will be PITA to get back.
And yes, that's not SanDisk, but relabeled SM2236. Memory chips are Toshiba and relabeled as well. Check the number of memory banks in the chip.
P.S.
And where's one more chip?
PostPosted: May 26th, 2016, 15:27
Agree, not encrypted.
We have done many 32gb and 64gb versions but not yet 128gb. :-)
PostPosted: May 26th, 2016, 18:12
Problem with videos is only for Sandisk controller. For rebranded SM controller video is ok. Translator can be rebuild correctly.
In FE there is problem with videos file - IMHO bad assembling algorithm. I have much more better result with videos when I assembling Sandisk controllers in VNR.
PostPosted: May 28th, 2016, 3:37
@ Dmitri 4 chips 4 banks
@ pcimage me too
@ arvika Images required only
reading dumps takes long time, sometimes i forget to switch chips and continue
thank you guys
