Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Interesting issue WD5000AVDS-63U7B0 - seqence 5click.
PostPosted: May 30th, 2016, 17:26
everything is show in screens
I was talking about error code in registers, not about pictures.
"WDC Marvell HDD repair....Registered user Peter_M" - hmmm, I think I guess about this Peter_M :)
Write back all original modules exept 02, 03, 31, 40. If drive clicks - so heads are not OK (can't pass start check). If not clicks - write these modules one by one untill drive start clicking. By doing this you can localize a problem.
PostPosted: June 6th, 2016, 9:39
Hi for all, I'm banned I don't no how. But Problem solved, I found problem why Click my WD AVDS. Problem identical
like my WD BLack WD2002FAEX, SHIT WDR........ Copy Made in WDR soft are bad :arrow: Mod 40 is this problem.
I prepared FW for ARCO procedure, and restart HDD, and success, Drive no Click, and Show Model XYZ ROM MODEL, SN correct, and FW version, so I Write mod from 01 do mod 39,
And restart hdd, and Drive again no click and correct initialize, Write mod 40, 41 reset drive and I hear Click click click click click pause click click click click click pause click click click click click pause click click click click click and spin down.
Further part are not write, because, does not make sense. It seems that you need to perform the procedure ARCO, do you understand me?
PostPosted: June 18th, 2016, 14:18
Case solved, My drive have bad servo or platter.
PostPosted: July 16th, 2016, 7:41
Lool, very lool, drive perfect complete ARCO, and Now running Self Test,
So, this case is veeeeeery interesting why Clicking, because previous drive clicking seqence, and now Running perfect.... :lol:
My disk still alive, Very interesting issue, Self test completed, and drive work perfect, not clicking, and not strange noises(borrowed PCB).
So finally :arrow: Previous Backup is corrupted, or lot of badsectors, can not propertly loaded translator, and finally clicking.
Btw: WD marvel is veeeery bug, and veeeeery poor, can not deal in many drives. :(
PostPosted: July 16th, 2016, 14:47
wdmarvel is not so bad ,also this is not marvel problem
and you can solve also by marvel , and support most family
this is FW prb not MARVEL PRB
i use it very long tie since first release
also i use auto Trex for refurbishing is best in such cases
http://www.hpwlab.com
PostPosted: July 16th, 2016, 14:48
even if hdd cliking will autofix that
check this video
https://www.youtube.com/watch?v=fhxVMxlQxkg
PostPosted: July 16th, 2016, 15:15
Yeah, right, but WD Marvell very few supports families drives, for example, does not support WD Black has big problems with ARCO, selftest in new drive, and thats all.
check this video
Auto trex Yeah, but Sediv repair tool I think based in Autotrex option, and system because
a lot of options has the same mechanism of action.
Well, Check again whether my old backup SA will work if no Backup SA corrupt 100%.
Trex support repair internal ROM? Using COM PORT?
PostPosted: July 17th, 2016, 21:29
check this video
for dead rom use UCommand is very easy for this issue
PostPosted: July 19th, 2016, 12:38
Yeah, but Ucommand not working in 1640.
Users browsing this forum: No registered users and 30 guests
