Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: Drive recognised but every sector is bad
PostPosted: June 3rd, 2016, 2:36
I have a WD400JB that will initialise and be recognised, but when I try to scan it in any program it cannot read any sector. Ubuntu recognises the full model name and firmware, and ddrescue will try to clone but just go through the entire drive forwards and backwards within a few minutes, but not able to read a single sector.
Does anyone know what could cause this issue? The drive has been opened but I didn't think the alignment issue applicable to some of these older WD drives was the case for the JB series. I thought maybe bad heads, but how would it know what sector it was trying to read if the heads were producing no signal?
The data isn't important enough for proper data recovery but I'm interested to try to work out what could cause such an odd issue.
 Post subject: Re: Drive recognised but every sector is bad
PostPosted: June 3rd, 2016, 3:35
Are you able to obtain a SMART report with a tool such as CrystalDiskInfo?
PostPosted: June 3rd, 2016, 4:28
Could be translator issue. Do you have any tool to work with this old model?
Those who know don’t talk. Those who talk don’t know.
PostPosted: June 3rd, 2016, 5:59
Some sort of firmware issue, damaged mod(s) I expect.
You'll require some sort of fw tool to check this.
PostPosted: June 3rd, 2016, 8:09
The issue isn't odd. As others have stated, it is most likely a firmware issue and some bad sectors. It likely would fall at the bottom end of the pricing scale at most reputable data recovery labs.
PostPosted: June 3rd, 2016, 12:33
I suspect that the drive may be repairable with free tools. If it can report SMART data, then I believe I can help the OP retrieve the other firmware modules.
PostPosted: June 4th, 2016, 0:03
I've attached photos of the SMART output from HD Sentinel and Crystal disk. Definitely doesn't look like its reading it correctly.
PostPosted: June 4th, 2016, 0:52
Try to dump the drive's ROM and firmware modules using NazYura's tools.
http://www.hddoracle.com/viewtopic.php?f=22&t=28&p=826
PostPosted: June 4th, 2016, 2:54
Would Mavr_r be the one I want? (Read Modules On WD-Hdd (For Marvell CPU))
In 32bit Windows XP in command prompt after entering
mav_r.com 10 logfile.log
It thinks about it for a while then give an error which says
Error: !!! Drive busy time out expired!!!
Status = -XX-XX
Do I need to be running it in DOS?
PostPosted: June 7th, 2016, 0:58
Woops wrong thread
PostPosted: June 7th, 2016, 1:12
NazYura's tools run from real DOS, not a DOS box in Windows. They expect to find your drive on one of the standard ISA ports, 0x1F0 or 0x170.
PostPosted: June 7th, 2016, 3:17
Ok using mavr_r I got it to work in DOS, it outputted 86 .MOD files. Is that all the firmware and ROM files? Or do I need to run one of the other utilities too?
PostPosted: June 7th, 2016, 3:24
I would capture all the tracks (MAVR_T) and ROM (MAVR_FL) for completeness, but the MODs should be enough. Can you ZIP them and upload them?
PostPosted: June 7th, 2016, 5:20
Ok done, got all 3 and put them in folders in the zip which can be found here
http://www.filedropper.com/mavr
PostPosted: June 7th, 2016, 12:32
Module 32 (and two others) is missing, as is track 2. The copies on head 1 are also missing.
I'll do more analysis in the morning.
PostPosted: June 7th, 2016, 14:53
Here are the missing/damaged modules:
ID   cyl         sector  size   function
0x2D 0x08 0x0000 0x011F 0x00B8  ID2D=SMART Log - Dump RAM
0x32 0x02 0x0000 0x01F6 0x0008  ID32=Translator:Grown
0xE1 0x0A 0x0000 0x0001 0x0258  SelfScan:log
0xE2 0x0B 0x0000 0x0001 0x0258  SelfScan:log
0xE3 0x0C 0x0000 0x0001 0x0258  SelfScan:log
0xE4 0x0D 0x0000 0x0001 0x0258  SelfScan:log
0xE5 0x0E 0x0000 0x0001 0x0258  SelfScan:log
0xE9 0x09 0x0000 0x0001 0x01AE  SelfScan:log
Module 32 is the translator. It needs to be regenerated. Unfortunately the copy on head 1 is not present in the dump. A partial dump of track 2 may have been useful, but it appears that NazYura's tools will only retrieve complete tracks. Likewise for track 8.
Here is a list of WD modules and their functions:
http://www.hddoracle.com/viewtopic.php?f=7&t=1176#p5285
SMART modules 20, 21, and 22 appear to be corrupt. They need to be cleared.
    ID20=SMART & Log Current
    ID21=SMART & Log Current
    ID22=SMART & Log Current
    ID23=SMART & Log Clear
    ID24=SMART & Log Main
You may wish to take up Spildit's generous offer. Otherwise we could use MHDD (ver 4.5, not 4.6) to send the Regen Translator command to the drive. Let us know what you decide.
PostPosted: June 7th, 2016, 15:23
Spildit wrote:
Translator problem almost for sure.
Very typical with cyl 32 drives.
ISTM this is a Marvell drive (pre-ROYL).
IIUC, it requires a different VSC for translator regeneration. :?
http://yura.puslapiai.lt/files/wd/mhdd/
; skriptas WD marvell translatoriu perskaiciavimas
; [WD Marvell script translator recalculation]
reset
waitnbsy
regs = $45 $0b $00 $44 $57 $a0 $80
waitnbsy
regs = $d6 $01 $be $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsfrom = mwtrrec.bin
waitnbsy
regs = $d5 $01 $be $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = i ; ( be )
; end
konfiguracijos sektorius mwtrrec.bin 512 byte pirmieji 16 likusieji  00  0x 0000 18 00 02 00 12 00 00 00 00 00 00 00 00 00 00 00
PostPosted: June 7th, 2016, 15:53
The grown defects list (G-list, MOD 34) is empty.
00000000  0C 0C 03 8C 34 31 33 32 44 3F 00 00 00 00 00 00  ...Œ4132D?......
00000010  00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000017F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PostPosted: June 7th, 2016, 16:16
ISTM module 32 is the relo-list in this model. :? If so, then it just needs to be cleared, AFAIK. We could try recovering it with a partial track read using an MHDD script. In fact only the first sector would need to be read. The remaining 7 sectors would be zero-filled. I think it is DIY-able.
PostPosted: June 7th, 2016, 17:41
We were recently working on your WD400JB-00ENA0 drive. The scripts I wrote for that were for "WD cyl 32" architecture. The OP's drive is a WD400JB-00FMA0 which is Marvell architecture. The directory modules for the two architectures are 41h and 01h, and the ID modules are 42h and 02h, respectively.
Users browsing this forum: Google [Bot] and 58 guests
