 Post subject: WD5000AZLX-00CL5A0 HEAD MAP
PostPosted: June 6th, 2016, 10:22
hi guys,
by any chance , someone knows the head map of this model ?
the family is Tresselb
 Post subject: Re: WD5000AZLX-00CL5A0 HEAD MAP
PostPosted: June 6th, 2016, 10:36
If I'm not mistaken these are one-platter drives with 500GB per surface.
So it should use only one head, ergo head map is either 0 or 1.
PostPosted: June 6th, 2016, 10:52
thats what i thought , but cant read anything from the drive
drive gets ready , correct id but reads nothing
PostPosted: June 6th, 2016, 11:39
have you tried to transfer the adaptives ?
PostPosted: June 6th, 2016, 13:45
it was the first thing that I tried.nothing changed. will go for head replacement
PostPosted: June 6th, 2016, 14:37
whoops, I thought you have replaced the HSA already
do you have access to SA ?
PostPosted: June 6th, 2016, 15:29
Same question, can you access SA?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: June 6th, 2016, 16:29
Doesn't ROM module 0x0A contain the head map?
If you are unsure of the head map of the donor, why not go for a 1TB donor instead?
Users browsing this forum: No registered users and 227 guests
