 Post subject: Seagate ST320LT007 No Access to Data Area
PostPosted: June 15th, 2016, 3:29
Above Hard disk is detecting perfectly and all modules are being read perfectly.
It throws following errors.
can't read any sectors in data area.
Heads are okay. Tried by Replacing it.
Any advice
 Post subject: Re: Seagate ST320LT007 No Access to Data Area
PostPosted: June 16th, 2016, 17:08
Hi, i faced same problem .. still i can't solve it ...
goodluck
PostPosted: June 16th, 2016, 18:02
may it can be translator issue. did you try regen or recover translator?
PostPosted: June 17th, 2016, 0:53
Translator Regen completes no effect.
Translator Recovery is not also not working
But drive reads sectors through Active Utility.
PostPosted: June 17th, 2016, 5:28
what is head resistance on terminal ?
could be heads
Data Recovery Pakistan
