 Post subject: Pinout of monolithic SDHC MMBGF08GWACA-GE 8GB
PostPosted: June 17th, 2016, 3:14
Hello everyone;
I have a monolithic SDHC, it seems that the controller is damaged and i can“t get the data from it, so i would like to know if there a possibility o recover the data from it, by connecting some wires to monolithics adapter, as PC 3000 adapter, The pictures below shows the type SDHC that i have. I'm not finding any kind of this SD Card. Any sugestions?
Thank you very much.
 Post subject: Re: Pinout of monolithic SDHC MMBGF08GWACA-GE 8GB
PostPosted: June 17th, 2016, 16:45
I have this pinout. http://odzyskiwanie-danych.com.pl/image ... arvika.jpg
This could be tricky case. In this case probably there is two XORs (grid + standard XOR).
Last time I have similar case which was solved. It looks like this:
PostPosted: June 17th, 2016, 16:51
Yes, very complicated case.
Not for the beginner!
Let Arvika handle the case for you, not many others can help with this nightmare :-(
PostPosted: June 17th, 2016, 17:27
WTF.. Arvika you are a genius...... :shock:
PostPosted: June 18th, 2016, 11:24
Well,
In flash he is
